Thread: difference between gen 2 and gen 3 heads
Results 1 to 8 of 8
  1. #1 difference between gen 2 and gen 3 heads
    I break stuff selliott's Avatar
    Kansas City
    What is the difference between gen 2 and gen 3 heads if any. I'm doing an engine swap in my 97 GT, I'm putting an 04 3.8 in and going turbo but I was going to save the head work until I do the turbo mod. I want to get it up and running NA first. Will the 97 heads work on the 04 or do I need to do the work on the 04 heads?
  2. #2 Re: difference between gen 2 and gen 3 heads
    the newer heads have bigger intake valves, but not much bigger. other than that they are pretty much the same.
  3. #3 Re: difference between gen 2 and gen 3 heads
    Kansas City
    So then if the newer heads already have bigger intake valves then it would be smarter to do the work on the new heads?
  4. #4 Re: difference between gen 2 and gen 3 heads
    yes, besides that they would more than likely have less miles on them too.
  5. #5 Re: difference between gen 2 and gen 3 heads
    Jersey
    97 heads tend to crack. Your going to need a trans to go with your setup too dude.
    16' wrx sti- stock
  6. #6 Re: difference between gen 2 and gen 3 heads
    Kansas City
    Yep building trans to go with it.
  7. #7 Re: difference between gen 2 and gen 3 heads
    Kansas City
    Hoping all said and done to have around 400hp at the wheels
  8. #8 Re: difference between gen 2 and gen 3 heads
    Kansas City
    But first it will be set up NA but will be built to withstand the power of the turbo.
  1. difference between 04-05 gtp and 06-07 gt?
    By miller in forum Off Topic Discussion
    Last Post: 04-12-2014, 06:36 PM
  2. Intense's S3 Heads VS. ZZP's S3 Heads.
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 02:08 PM
  3. Difference between GTP and GXT... is there one?
    By kjclawson in forum General Tech Discussion
    Last Post: 08-09-2009, 12:34 PM
  4. Is there a difference between 05 and 06 GXP
    By baw1099 in forum Off Topic Discussion
    Last Post: 06-29-2008, 10:17 PM
  5. difference between gt and gtp trans
    By robahr24 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-13-2008, 07:30 PM
