Thread: TB Question
Results 1 to 8 of 8
  1. #1 TB Question
    new york
    Alright so coupled along with the mods in my sig which TB would be the best and/or the easiest to install and give the best performance gains. A ported TB from Reptile, a HVTB from ZZP, or I heard you can swap on a GTP TB?
    2002 GP GT - 180* T-stat, DIY 4"FWI, ZZP PLOG, 2.5" catted DP, DHP PCM, HV2,
  2. #2 Re: TB Question
    none, a TB wont give you any gains. get rockers and a bigger downpipe.
  3. #3 Re: TB Question
    Donating Users chrisb's Avatar
    Bucyrus, OH
    Really? And do you know this by experience?
    Sure with rockers you would gain more hp but thats not what he is asking.
    Im not sure what reptile charges to port a tb but im sure its cheaper then zzp though. I dont know if reptile has the ability to install a larger throttle body blade like zzp's stage 2 tb. I have a zzp stage 2 tb but a maf tune is reccomended to run it. Now for l67 throttle body I dont know if the maf tables in the tune are the same or if in fact the tb its self is larger. someone else would have to chime in on that one.
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  4. #4 Re: TB Question
    Get a ported L67 throttle body from Brian with rockers and GTP injectors...and a custom tune...that thing will move for a N/A car.
  5. #5 Re: TB Question
    new york
    Will an L67 TB just bolt right up though? or will I need an adapter or to rig up something to make it work? And I realize I'm going to see negligible performance gains if any but what about the difference in throttle response between them? (btw Bio ER rockers are probably going to be my next mod over the summer)
  6. #6 Re: TB Question
    Jersey
    someone did a N* on a GT, not sure why but, it was cool. Reptile does the best porting around. To be honest, the money your going to spend wouldn't be worth the gains. It doesn't make much sense to me if you have a ported t/b with a bigger bore than the inlet on the plenum. It would just make an air step imo
    x2 on getting rockers now, get 1.9's with L76 valve springs
    16' wrx sti- stock
  7. #7 Re: TB Question
    whoops...I meant port the L36...my bad.
  8. #8 Re: TB Question
    an l67 TB you would need an adapter.
    although, the gains youll see from a ported TB are so minimal that i wouldnt waste my time. it was the biggest let down out of any of the things i did to my car.
  1. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  2. Question: Supercharger question.....
    By nmaponte in forum General Tech Discussion
    Last Post: 03-12-2009, 01:04 PM
