Thread: GT to a GTP
Results 1 to 18 of 18
  1. #1 GT to a GTP
    Minnesota
    I drive a 2000 GT and i was just wondering if i were to drop a GTP engine into it, would i need to worry about things like the engine mounts not lineing up? Also, what else would i need to wire into the firewall other than the boost control stuff.
  2. #2 Re: GT to a GTP
    Using your existing harness it's two wires from the BCS to the PCM and a harness adapter for the map sensor. Mounts are all the same.
  3. #3 Re: GT to a GTP
    Jersey
    I'm pretty sure the flexplate is different too.
    Have you looked at other options, like a top swap?
    Would you be swapping the trans too?
    16' wrx sti- stock
  4. #4 Re: GT to a GTP
  5. #5 Re: GT to a GTP
    Wausau, WI
    topswap would be faster, cheaper, and more HP in the end.
  6. #6 Re: GT to a GTP
    Quote Originally Posted by Liquifire View Post
    not necessarily true on any of those points.
  7. #7 Re: GT to a GTP
    Wausau, WI
    stock configuration yes, it is true. The worst it could possibly be cost wise is a tie unless you are counting the cost of gaskets and the small stuff. If both motors are in good condition, you will have more power with the NA motor top swapped obviously. It should be faster as you would still be using the stock NA tranny with 3.29's and the motor has more power with stock configuration. Once it is modded then the cost goes up, and the speed bets are off.
  8. #8 Re: GT to a GTP
  9. #9 Re: GT to a GTP
    Wausau, WI
    what you need to do is top swap that impreza, or better yet turbo...
  10. #10 Re: GT to a GTP
    ill let you know how that works out when i get a job again.
  11. #11 Re: GT to a GTP
    Maryland
    Can you drop 3.8 SC engine into a 3.8 Non SC 97 GT. I have the 3.8 complete SC engine. DO I have to change the tranny? Thanks.
  12. #12 Re: GT to a GTP
    Wausau, WI
    yes you can do it, you can use that tranny, but it wont last forever. You could baby it and make it last a little while, but what fun would that be?
  13. #13 Re: GT to a GTP
    yes, you have to change the transmission. well, technically you wont, but youll regret it later if you dont.
  14. #14 Re: GT to a GTP
    Wausau, WI
    If you need a tranny, go with a TEP and be done with it.
  15. #15 Re: GT to a GTP
    Barksdale AFB, LA
    Then you can pick up an EJ257 and call it a day.
    2009 Subaru Impreza WRX STI
  16. #16 Re: GT to a GTP
    Jersey
    x2 that. Dave is the best! I should have mine next week
    16' wrx sti- stock
  17. #17 Re: GT to a GTP
    You won't REGRET it...I love mine...and from going from 2.93 gears to 3.29 gears...
    Epic.
    Win.
  18. #18 Re: GT to a GTP
    Quote Originally Posted by Sabrewings View Post
    id buy a new car before putting FI on this one. its a waste.
gtp
