Thread: 180 t-stat for stock GP?
Results 1 to 20 of 20
  1. #1 180 t-stat for stock GP?
    PA
    Hey Guys,
    When I replaced my LIM/UIM gaskets I threw in a 180 degree T-stat. My motivation was purely to reduce engine wear - not looking for performance gain.
    Anyway, I've been reading and heard differing opinions - so wondering if you can help me out. Should I not use it in a stock GT? I heard that the engine can get even hotter running it, how is this possible?
    I assume it has something to do with the pcm commanding the cooling fans on but not sure.
    Sorry if this has been addressed already I searched and didn't find much.
  2. #2 Re: 180 t-stat for stock GP?
    if the car is moving, your car should be sitting at 180 when warmed up and running. If you pull hard and stop moving the temp will shoot up to ~195 where the cooling fans will turn on. Perhaps thats what people were talking about the engine running hotter.
  3. #3 Re: 180 t-stat for stock GP?
    just leave a stock thermostat. 180* isnt technically a good running temperature for the engine to not wear as much. you also wont be able to make use of the 180* thermostat unless you are moving or have the fan turn on times set lower.
  4. #4 Re: 180 t-stat for stock GP?
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    i just drilled my 195 lol
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  5. #5 Re: 180 t-stat for stock GP?
    in the dead of winter where it gets as low as -30 below, drilled t-stats are a fail.
  6. #6 Re: 180 t-stat for stock GP?
    PA
    Actually, if you are looking to reduce wear on your engine, a cooler t-stat is doing the complete opposite. The cooler t-stat you use, the more wear on your engine components.
    2001 GSE
  7. #7 Re: 180 t-stat for stock GP?
    prove it. i ran a drilled 180* in WI winters for a few year already. no ill effects at all.
  8. #8 Re: 180 t-stat for stock GP?
    PA
    Other than fuel mileage? ;-)
    2001 GSE
  9. #9 Re: 180 t-stat for stock GP?
    Takes the car longer to warm up. If your average drives are short, the car won't be warmed up for very long if at all.
  10. #10 Re: 180 t-stat for stock GP?
    car was warmed up in 5 minutes of a 13 minute drive in the dead of winter. no problems here.
  11. #11 Re: 180 t-stat for stock GP?
    I drive 5 minutes to work and the car is barely reading on the scale. Also noticing since switching to 5w30 syn its taking longer to warm up versus 10w30
  12. #12 Re: 180 t-stat for stock GP?
    "on the scale" is about 160*. thats good for knock sensors being enabled, heat working, and the car being nearly to temp.
  13. #13 Re: 180 t-stat for stock GP?
    fair enough
  14. #14 Re: 180 t-stat for stock GP?
    PA
    Hey thanks for all the replies guys.
    If it matters at all, I do about 90% highway driving.
    I did notice that when sitting idle the temp gauge starting going up a bit..
    98 GT stock
  15. #15 Re: 180 t-stat for stock GP?
    PA
    Quote Originally Posted by chantspel View Post
    For a stock car, GT at that, in PA, doing hwy driving, your best bet is to stick with a stock 195° t-stat.
    2001 GSE
  16. #16 Re: 180 t-stat for stock GP?
    PA
    Thanks guys. Looks like I'll be putting the stock one back in.
    About how much coolant needs to come out before I can swap it out?
    98 GT stock
  17. #17 Re: 180 t-stat for stock GP?
    Kansas
    I never took any out
    SOLD 1999 GT Silvermist TS
  18. #18 Re: 180 t-stat for stock GP?
    PA
    Quote Originally Posted by Gafford44 View Post
    X2. A little may come out when you do it. But you only lose like a quart, at most. Not really a big deal.
    2001 GSE
  19. #19 Re: 180 t-stat for stock GP?
    PA
    Lol yeah but I'm not trying to get coolant all over my garage floor...
    98 GT stock
  20. #20 Re: 180 t-stat for stock GP?
    you will unless you take some coolant out of the system by pushing it into the overflow by squeezing the upper rad hose. Even then, there'll still be some left in the t-stat housing that you won't be able to get out without taking the t-stat housing off.
  1. 180 T-Stat
    By xerxescct in forum General Tech Discussion
    Last Post: 07-08-2009, 11:19 AM
  2. 180 T-Stat
    By wykabryan in forum General Tech Discussion
    Last Post: 11-17-2008, 03:27 PM
  3. Which t-stat should I get?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2008, 08:49 PM
  4. 180* T-stat
    By offroadfury6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2008, 10:30 PM
  5. t-stat ?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 04-29-2008, 11:30 AM
