I would rule out a stress fracture...like I posted previously, doesn't seem that it's mis-mounted in any way...
For this to happen it would not have to be mis-mounted. It could be that the sub frame is flexing more than it was supposed to. Did you get a NEW radiator to replace the original or used? Is it a GM radiator or aftermarket? what type?
