Thread: Engine running too cold?
Results 1 to 3 of 3
  1. #1 Re: Engine running too cold?
    Oklahoma
    The 180* T-Stat will allow it to run cooler obviously and you dont need to change or program the PCM to do so as far as I know. If you look at the temp gauge, there are four major marks on it and two smaller marks between each of those. GM and their techs would have you run an engine temp that puts the needle at the middle of the gauge. Ive asked GM mechanics before and was told they like to see about 200 - 210 which to me is a bit too hot.
    The 180* T-Stat I run (its drilled also) puts my cruising temp just above the first major mark, usually about the first minor mark after that and it will go up and down around there. In town it will go up some but I have my PCM programmed to kick on the fans around 185 I believe.
    You can indeed run an engine too cold. If your thermostat were ever to stick open you will find that it will run cool enough to cause some stumbling at idle and you will most certainly use a bit more fuel. 180* is about the coolest thermostat I would ever use in a passenger vehicle.
  2. #2 Re: Engine running too cold?
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    I'll keep an eye on it then over the next few weeks. From the code I was given, I also read that it could be a bad temperature sensor. I don't think the new thermo is stuck open, and there's been no code thrown since I put the new one in and cleared the error. But could the bad temp sensor keep the coolant flowing? There's been no stumbling at idle, and a quick computation of the MPG average was 24, a mix of highway and city. About right. Then again, maybe the gauge is just wrong. I believe my ODBC2 code reader might also monitor temperature. Worst case, I get the Aeroforce gauges to go in the Impala pillar gauge holder and check it out in the GP for a while.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  1. making a cheap cold air intake ?
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2010, 04:10 PM
  2. Making a cheap cold air intake [*]
    By nvsridez in forum How To Write-Ups/Tech Tips
    Last Post: 11-05-2009, 10:10 PM
  3. Custom Cold Air Induction [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 07-04-2009, 05:05 PM
  4. Running speaker wire....to the doors....help.
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2008, 02:14 PM
  5. What brand/style of tires are you running?
    By John02Hawk in forum Tires & Wheels
    Last Post: 02-15-2008, 01:18 AM
