Thread: Car won't fire after LIM install
Results 1 to 16 of 16
  1. #1 Car won't fire after LIM install
    Milwaukee
    After I put the engine back together and went to start (I had already changed the oil after install) it would try to start then stop. Finally got it going for a few minutes, gave it gas because it sounded like it just needed to burn out some crap. Well doing so the engine just stopped. Tried pulling a spark plug to see if any fuel was at least getting to it, coolant started pouring out of the hole. Without tearing it apart (probably will start to do that soon) anyone have any idea as to what has failed? I don't know a lot but I do know coolant should not be pouring out ha ha.
  2. #2 Re: Car won't fire after LIM install
    Milwaukee
    Forgot to add i swapped out new spark plugs also, my old ones needed changing so I doubt its the plugs.
  3. #3 Re: Car won't fire after LIM install
    Charles City, IA
    You are saying the cylinder is filled with coolant? If so It is either the head gasket or the LIM is leaking coolant into the cylinder some how. You need to pull the heads.
    SMGPFC Two Nipple General
  4. #4 Re: Car won't fire after LIM install
    Milwaukee
    Yeah I hooked up a hose to a meat syringe and sucked a bunch of coolant out of the cylinders. Also it just won't start at all now. Could the whole thing just be locked up?
  5. #5 Re: Car won't fire after LIM install
    Charles City, IA
    You mean it wont turn over? I would stop trying to start it. You have liquid in the cylinders liquid does not compress and you are going to bend a rod it you have not all ready?
  6. #6 Re: Car won't fire after LIM install
    Milwaukee
    Well after I found out coolant was in there I have not tried, before I checked I meant it wouldn't turn over at all.
  7. #7 Re: Car won't fire after LIM install
    Charles City, IA
    If it will not crank at all you need a new short block.
  8. #8 Re: Car won't fire after LIM install
    Milwaukee
    That's exactly what I was hoping wasn't the case... going to get it towed to a local shop on monday just to get it checked for sure before dropping money/getting a new car... Thanks for the help though man
  9. #9 Re: Car won't fire after LIM install
    Charles City, IA
    Why get a new car? You can get a block and rotating assembly for around $500
  10. #10 Re: Car won't fire after LIM install
    Nov 2008
    norman oklahoma
    dont tow pull the plugs and drain the af then spin the motor over with no plugs in it spin with the ign key to blow all of the af out of the cylinders it will be messy get some oil soak .after you do this drain the oil now!! then pull your upper intake and replace it you will have to replace plugs again but this will fix your problem did you replace upper intake or reuse old one
  11. #11 Re: Car won't fire after LIM install
    Milwaukee
    Thanks for that tip, i'll have to consider that. I'm at school right now so i've been going home on the weekends to work on it.
    Will that work if it won't crank at all? We managed to get a ton of coolant out by sucking it out with a small tube, but like i said before, when we went to start it, nothing but a quick grind sound and it would stop.
    I reused the upper intake, and if you're talking about the gasket also I reused that too.
  12. #12 Re: Car won't fire after LIM install
    That's why...the gasket was prolly shot and hello coolant into your motor.
    I'd drain the oil...get new plugs...new LIM gaskets (GM ONES, not Felpro CRAP)...get it all cleaned up and if it starts...let it run for a minute...rev it up...then shut it off after there are no leaks...and change the oil again...filter too.
  13. #13 Re: Car won't fire after LIM install
    Destroys cars izup69's Avatar
    Iowa
    pull the heads make shure u didnt bend a rod or the crank for that matter replace all gaskets rebuild BETTER hehehe and then drive the **** outa it
  14. #14 Re: Car won't fire after LIM install
    ^^What?
    That was a ridiculous statement to tell the guy. Have you ever seen a bent crank in a N/A 3800 car? Or Rod for that matter?
  15. #15 Re: Car won't fire after LIM install
    Banned - Busted For Scamming
    Feb 2009
    OOOO i have lol!!
  16. #16 Re: Car won't fire after LIM install
    Nov 2008
    norman oklahoma
    you do not need to pull the heads!!!!!!!!!!!! but you do need to drain the oil, also the upper intake needs to come off. and go get 2-3 quarts of cheap oil and pour the oi lin the valley to flush the af out of the upper part of the motor. the af is corrosive to bearings that is why you need to do this and then do like bluegtp91 says but time is of the essence
  1. Fire Extinguisher mounted.
    By GR8racingfool in forum General Tech Discussion
    Last Post: 02-12-2010, 03:52 PM
  2. my a$$ is on fire...lol
    By cojo in forum General Tech Discussion
    Last Post: 05-10-2009, 09:32 PM
  3. Mis-Fire #5
    By gtbeach in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2009, 11:39 PM
  4. Tractor Fire
    By TCO in forum Off Topic Discussion
    Last Post: 07-10-2008, 11:50 PM
  5. No fire on #3 cyl, injector problems??
    By gplostinnd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2008, 12:28 AM
