Thread: Tensioner torque
Results 1 to 10 of 10
  1. #1 Tensioner torque
    GT Level Member hacket's Avatar
    USA
    Ok so I've been looking around and have determined changing my serpentine is pretty straight forward. But I'm finding nothing about how much to tighten the tensioner when I put it back on. I've never worked with it so I don't know how it works.
    Does it just tighten to a specific point on it it's own or is there a torque level I have to tighten to?
    Thanks guys.
  2. #2 Re: Tensioner torque
    Wausau, WI
    when you say "put it back on" I am assuming that you mean the belt. The tensioner has a built in level that it puts pressure on the belt with. You should just have to take the old belt off and put the new one on with no adjusting. You should not have to remove any other parts other than the belt to put a new belt on.
  3. #3 Re: Tensioner torque
    USA
    Ok thanks. I just didn't know how the tensioner works.
  4. #4 Re: Tensioner torque
    Wausau, WI
    when you put the wrench on the nut you will move it back to take tension off of the belt to get it off. You will need it pulled back to get the belt on all the way and then just release it. It will go to the proper pre set tension level.
  5. #5 Re: Tensioner torque
    USA
    Thanks man that's exactly what I wanted to know. I ordered my belt off of RockAuto two days ago so just waiting for that now. Only 30 bucks total. It's awesome how much you can save doing things yourself.
  6. #6 Re: Tensioner torque
    USA
    Well I did it Removed and replaced the belt for the first time ever. Must say I'm pretty proud...even if it is a small item.
    Hardest part was moving the tensioner. I had to run to the hardware store and buy a crescent wrench. My socket wrench just wasn't strong enough....and my large socket didn't have a 15 mm. Thanks for the help Liquifire.
    http://faceyourfinances.blogspot.com/
    1998 Grand Prix SE 3800 Engine, Metallic Green, Gold Rims with stock spoiler, Bought with 112K in May 05; Currently : 182K
  7. #7 Re: Tensioner torque
    Charles City, IA
    Go to sears and buy a 200 piece craftsman set for like $200. Then buy one long ratchet. You will be set for a lot of things then.
    SMGPFC Two Nipple General
  8. #8 Re: Tensioner torque
    Wausau, WI
    no problem, that is what we are here for. Now you have somewhat of an idea for next time. Everything is much easier the second time around. Having the proper tools makes everything a lot easier too. With the money that you saved by doing it yourself you can slowly buy tools as you need them. Yes, a large ratchet and breaker style bar come in handy often... purchase them when you can.
  9. #9 Re: Tensioner torque
    USA
    Sounds great. I'll keep that in mind.
  10. #10 Re: Tensioner torque
    Ohio
    why buy a 200 piece tool set. buy a serpentine kit instead! It makes removing belts a snap! AutoZone.com | Serpentine Drive Belt Tool | 3/8 in. Drive Serpentine Belt Tool with 1/2 in. Drive Adapter, 13, 15, 16 and 18 mm. Sockets
    00 GTP demodded and forsale
  1. GXP serpentine tensioner
    By 05 GXP in forum 5.3L V8 (LS4)
    Last Post: 07-23-2009, 11:38 AM
  2. Belt Tensioner
    By LANCER in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2009, 09:40 PM
  3. serpentine tensioner
    By boosting98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2009, 08:20 PM
  4. Replies: 12
    Last Post: 02-08-2009, 01:06 AM
  5. New tensioner from ZZP
    By IndeedSS in forum Off Topic Discussion
    Last Post: 01-22-2008, 08:31 PM
