Thread: Temperature sender location
Results 1 to 15 of 15
  1. #1 Re: Temperature sender location
    Bastard Reptile's Avatar
    Kansas City, MO
    Quote Originally Posted by 19SE92 View Post
    Nope SynthiceSheild the sensor your refering to is the cts coolant temp sensor. The sensor for the gauge it self should be in the rear head. Your facing the front if the car look for a single green wire it should be in the corner of the head clostest to the drivers side of the car. It takes a 15mm wrench or socket to get it out.. That its about 20-25 ish for the sensor. The coolant temp sensor is between 20-50 bucks and it takes a 3/4 or a 19mm wrench to remove.. Hope that helps
    Negative. Stick to your 3.1.....you've obviously never opened the hood of a 3.8 series 2 before.
    Scotty is correct, it's under the thermostat housing on the drivers side of the intake. That is the ONLY temp sensor for the engine. It feeds the PCM, and the PCM is what feeds info to the cluster.
  2. #2 Re: Temperature sender location
    Hoffman/Schaumburg, IL
    for the cup holder, that hole center peice usualy gets replaced,
    contact Ed : Morad Parts Company - Your source for 3800 parts!
    The whole peice comes out pretty easy:
    Engine off, Put gearshift into 2nd gear, then remove the liner from the center storage bin, then pull up on the center console top peice, starting at the storage bin and working forward, the cupholders should be folded out for this...
    Oh, and if you have heated seats the switch and plate need to be lifted up an either detached or find a way to squeez it through the hole. ( i found a quarter is perfect to pop up this switch plate, weird huh)
  3. #3 Re: Temperature sender location
    Oklahoma
    Quote Originally Posted by Reptile View Post
    Scotty is correct
    Can you say that again please, I just never tire of hearing that.
  1. User location Map
    By 3800SE in forum Forum Bugs/Suggestions
    Last Post: 01-25-2008, 08:23 AM
  2. Oil Level Sender Thread
    By Speeder in forum Turbo
    Last Post: 01-08-2008, 09:25 PM
