If your willing to spend money then do a turbo kit.
If not...then top swap it.
If you don't want to go THAT far...then read by thread in the General Tech Section called Safely Modding your 3800 Powered Car.
IMO
TDC Racing Fenderwell Intake
180* T-Stat
3800 Performance PCM (intense's are junk)
3" Catted Downpipe
ZZPerformance Front Powerlog
Flipped Motor Mounts
ZZPerformance HV3 Upper Insert
And...if you want a little more...High Ratio Rockers, 1.84:1 Roller's...b/c you can use stock valve springs and should giveu about 15-20 horsepower.
seems like a stupid question, but what would flipped motor mounts do?
