Thread: head gasket and lim install and now 2 problems
Results 1 to 13 of 13
  1. #1 Re: head gasket and lim install and now 2 problems
    GT Level Member tylerbinski's Avatar
    Canada
    check the pins on the MAF plug are not bent.
    Could be running in VE mode and using the Bad fuel spark table in the PCM. CEL is not illuminated first start when MAF failure is detected.
  2. #2 Re: head gasket and lim install and now 2 problems
    Also pull the EGR tube from EGR to LIM manifold if you bent it out of the way or treated it with anything but "please don't break" type of respect.
    They are thin and can crack right at the the edge which causes a vacuum leak and commonly a P0171.
  1. Head Gasket? Or LIM ??
    By JAllegar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-08-2009, 08:50 AM
  2. So.......Is it a head gasket
    By 04BlackComp_G in forum General Tech Discussion
    Last Post: 03-22-2009, 04:58 PM
  3. Possible Blown Head Gasket
    By Blk99GpGt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-09-2009, 12:40 PM
  4. head gasket?
    By Mikefisher in forum General Tech Discussion
    Last Post: 10-10-2008, 12:36 PM
  5. Possible Head Gasket?
    By msmenne17 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-12-2008, 10:44 PM
