Thread: Question
Results 1 to 12 of 12
  1. #1 Question
    Feb 2008
    what would be some good "cheap" upgrades for my grand prix that would increase the hp and torque
  2. #2 Re: Question
    Banned
    New Port Richey Florida
    First off welcome to the board. Lets get to the bottom of this. What are the specs for the the grand prix that you have? If you post the specs that will give the board a better idea for what kind of parts that your looking for to make a tad bit more power.
  3. #3 Re: Question
    Feb 2008
    i havent put any upgrades on it yet well preformince wise any ways
  4. #4 Re: Question
    Oklahoma
    Quote Originally Posted by Tyler_06 View Post
    Well since you posted in the L36 section I'll make the assumption that you have a N/A 3.8L, so if that is true we really dont need specs on your Grand Prix.
    First of the cheap upgrades would be an intake. You can make one yourself or buy and aftermarket one. There are some trade offs to be considered, so you kinda have to decide just what you want and any long term plans.
    Next would be the ignition system. Probably the best thing to do there is use copper core plugs and low resistance wires. This will give you better spark and help you make better use of the air/fuel mixture and thus give you a tad bit better performance and possibly better fuel economy.
    Next up would be a 180* thermostat. Not really a performance upgrade but it will help some with KR if you have any. And if you have KR then you are loosing performance by virtue of the fact that the computer will pull timing. I personally recommend the MotorRad thermostats because when they go bad, they lock into the full open state instead of being closed and causing your engine to overheat. They are a bit more pricey but worth it. Ive already benefited personally from that feature a couple years ago.
    Getting a little more up in the expense range, you could get an Overkill Motorsports PCM. Thats gonna run you $160 or so, I dont remember exactly what the prices are but he is well known for his PCM tuning and he has a great reputation for his PCM's really waking up a car. Its a bit more money but I personally think its worth it.
    You could also do a U-bend delete or a downpipe with the ubend delete but that too could run you $150 or more depending on what you get. I would even put that on the highly recommended list of things to do.
    There may be some other suggestions out there but those are the ones off the top of my head and hopefully they help you get started without having to dig up all the specifications for your Grand Prix.
  5. #5 Re: Question
    Feb 2008
    Thak you that helps a lot oh and i want to get a sound out of my muffelers but i dont want to buy the hole cat back for fifteen hundred dollars and i dont want the little riceburnr sound either is that possible?
  6. #6 Re: Question
    Oklahoma
    Its all about acoustic tuning and while I think its possible and Ive seen examples of it, I dont know what all is needed. I have also seen my fair share of examples of GP's that sound friggin' SWEET at idle but get them up around 2000 rpm where you do most of your highway type driving at, and it gets raspy and has a drone to it.
    So to ultimately answer your question you may have to wait for input from others. I know there are some combinations out there that work well. Heck, using stainless steel over aluminized type pipes will give you drastically different sounds.
  7. #7 Re: Question
    Bastard Reptile's Avatar
    Kansas City, MO
    The ones I run are Dynomax. They are the quietest performance ones that I have found for the W-body, and they don't have a bad sound. If you leave the resonator in, it's still very quiet in the cabin.
  8. #8 Re: Question
    Banned
    I do as well they have a little sound to them but there not over the top like most are i got mine installed 200 bucks out the shop door there called thunder bolts if anyone has heard of them.
  9. #9 Re: Question
    Kansas City, MO
    Actually, mine are the Super Turbo mufflers....they show as a direct factory replacement on the Monte Carlo, but work on GP's as well.
    Part numbers are 17667 LH & 17666 RH.
  10. #10 Re: Question
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    I'd say first thing is to come up with a budget. Because you're sure to stick to that.
    But it is a good starting point. I put a budge of about $2500 for my 04 Impala SS. A big chunk of that was headers, downpipe, and cat-back. But there are other "cheaper" mods you can do that don't impact the wallet as much. Intake, plugs, Powerlog or PEMS, new PCM, throttle body, and a lot of other mods can be picked up for $100-$200. You can spread out the love so the hit to the wallet isn't as dramatic as well, and it makes you think you're not spending as much as you are!
    Plus, figure out what you want to do with the car. Are you going to race it, or use it as a daily driver? My Imp is my "performance" car so I'm more willing to spend on the upgrades for it. My GP is my daily driver, so some things I'm in no hurry to do, if I will do them at all.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  11. #11 Re: Question
    Feb 2008
    does hitting the track off button make the car go faster?
  12. #12 Re: Question
    Feb 2008
    Cumming GA
    If sliding on the ice is faster, sure.
  1. cai question
    By kingd44 in forum Off Topic Discussion
    Last Post: 02-19-2008, 07:27 PM
  2. question
    Last Post: 02-09-2008, 10:43 PM
  3. question
    Last Post: 02-08-2008, 03:46 AM
  4. question
    Last Post: 02-04-2008, 03:59 PM
  5. 97 PCM question
    By TJs97 in forum PCM Tuning
    Last Post: 01-31-2008, 12:18 PM
