Thread: Car stumbles after startup and has a jumpy idle
Results 1 to 8 of 8
  1. #1 Re: Car stumbles after startup and has a jumpy idle
    SE Level Member Lionel's Avatar
    Moncton N.B.
    is the throttle body what's connected to the air intake? just before it hits the engine?
  2. #2 Re: Car stumbles after startup and has a jumpy idle
    Moncton N.B.
    I have the throttle body in front of me, and all i see is a trap door looking thing, clean on one side and full of carbon on the other, am i supposed to remove the plastic cover on the side and clean up all in there?
  3. #3 Re: Car stumbles after startup and has a jumpy idle
    Jan 1970
    Maquoketa, Iowa
    Check your MAF sensor or clean it. You can unplug it to see if it changes anything in the idle. If you don't notice anything change, there's a good possibility it may need replaced or cleaned. If it does change the idle after it is unplugged, thats not it, check for vac leaks.
  1. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  2. Bad lag on startup & accelleration
    By Jsedor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2009, 03:07 PM
  3. knock at startup
    By Jakegday in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2009, 08:01 AM
  4. oil burn at startup?
    By Golgo13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2008, 07:18 PM
  5. Hard startup and noise
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 05-31-2008, 04:58 PM
