Thread: T-Fitting for my vacuum line & boost gauge.
Results 1 to 4 of 4
  1. #1 T-Fitting for my vacuum line & boost gauge.
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    I have been attempting to locate a rubber t fitting for the vacuum line. I need one to replace the cracked one on the passenger side just under the S/C snout and another to run a boost gauge (behind the blower near the map sensor.)
    Does anyone know where i can find this rubber t fitting? Or better yet if i can get them from GM is there a GM part number?
    I have found plastic ones in the Autoparts stores but they were either too big or too small. The closest one fit the hose but the lip, like 1/8 of an inch down on the hose, did not fit thus making the fitting too small.
    Any help is appreciated!
    2006 Grand Prix GXP
  2. #2 Re: T-Fitting for my vacuum line & boost gauge.
    Jul 2008
    New York
    How did i end up in the n/a section?!?! Sorry plz delete this ill re-post in the correct area.
    2006 Grand Prix GXP
  3. #3 Re: T-Fitting for my vacuum line & boost gauge.
    Wausau, WI
    talk to your dealer about the part.........they should be able to get you a part no......
  4. #4 Re: T-Fitting for my vacuum line & boost gauge.
    Outer Space
    You can make your own T-Fittings by purchasing the 1/8" plastic vac line t's from your autoparts store. Use some rubber tubing.. to connect the 1/8" lines to the T.
    02 GTP 13.6 @ 100mph - SOLD
  1. Boost Gauge and vacuum line
    By anicolay in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-22-2009, 12:58 PM
  2. Vacuum line...where does it go
    By chrizzle17 in forum General Tech Discussion
    Last Post: 02-25-2009, 11:15 PM
  3. brake line fitting ?
    By quiksilvergt in forum Brakes/Suspension/Chassis
    Last Post: 09-21-2008, 06:42 PM
  4. What is Vacuum on a boost gauge ??
    Last Post: 04-07-2008, 12:54 PM
