Thread: starting problems
Results 1 to 14 of 14
  1. #1 starting problems
    Feb 2008
    i have a 2004 gpgt when i first start it the car starts just fine. If i turn it off it then will not start unless i mash the throttle and crank it. Then it starts, happens just here and there throughout the day. Someone please help.
  2. #2 Re: starting problems
    Oklahoma
    Do you have the drive by wire system?
  3. #3 Re: starting problems
    Feb 2008
    Not sure what you mean. I know very little about all the newer stuff. I usually have older vehicles.
  4. #4 Re: starting problems
    Oklahoma
    The newer vehicles have a throttle body that is electronically controlled rather than by a mechanical linkage. But yours is a 2004 and Im not sure if that is the year they went to that system or if it was only on the supercharged engines.
  5. #5 Re: starting problems
    Feb 2008
    oh, yes it is electronicly controlled.
  6. #6 Re: starting problems
    Oklahoma
    Well unfortunately I am not terribly familiar with that system. But I would have to say, given the fact that you have to mash the gas and then crank it, that that system would be suspect. Its a fuel injected car so there is no need to mash the gas at all to get it to start.
    I suppose there could be a fueling problem but I dont see how mashing the pedal would overcome that or change it enough to start the car.
  7. #7 Re: starting problems
    Feb 2008
    i hear ya, it doesn't start if i just give a little throttle, but it will if i have it full throttle. I live in a small town so the mechanics here suck. I try to fix things myself but have no idea here.
  8. #8 Re: starting problems
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    Quote Originally Posted by redgt View Post
    it sounds like it could possibly be the switch on the gas pedal....
  9. #9 Re: starting problems
    Feb 2008
    its worth a shot i will try loking in that direction. thanks
  10. #10 Re: starting problems
    GTX Level Member MTXGTP's Avatar
    wamego,KS
    i would try turning the ignition off and watch the the flap and see what it does it should leave it partially open and this is incase the motor that operates the flap fails i would say that it might be sticking how many miles is on it?
    Justin Young, Kansas
    1999 silver GTP DHP pcm,3" Cattless hogan DP,Front PLOG,3.4 pulley, ported TB, ported LIM, ported supercharger housing.porting done by GBP
    coming soon: LS6 springs ,1.9rr
  11. #11 Re: starting problems
    Feb 2008
    72,000 miles
  12. #12 Re: starting problems
    Feb 2008
    i read some other posts and they were having the same problems. It hasn't been doing it lately but it did rain and snow about a week ago and all melted. Wonder if it had something to do with moisture messing something up?
  13. #13 Re: starting problems
    Apr 2008
    im having the same problem with mine. If I drive it around for a bit and then go shopping or something the car wont start unless I tap the gas pedal and crank the engine.
    Also my friend is having the same problem. Where trying to figure it out. Seems like alot of people have this problem but never saw anyone that has a solution
  14. #14 Re: starting problems
    Hoffman/Schaumburg, IL
    Could the car be running to rich? Cause WOT while cranking causes the computer to shorten the Injector Pulse widths and lean out the engine and if the engine has too much gas from running a little rich, it may take a leaner crank to start it up...Hope that made sense....
    Also check TPS?
  1. General Starting and Engine Troubleshooting Guide [*]
    By TyroElite in forum How To Write-Ups/Tech Tips
    Last Post: 12-15-2010, 12:24 PM
  2. well I am starting a new audio build. This time it is sq.
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 05-01-2008, 06:08 PM
  3. Starting Problems
    By SahotaGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2008, 01:38 AM
  4. Starting with mods
    By Pontiacman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-04-2008, 09:25 AM
  5. Problems Starting after Engine Replacement.
    By Metallistar in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2008, 07:54 PM
