Thread: still not firing
Results 1 to 4 of 4
  1. #1 still not firing
    Gaston
    has no spark, tested the icm- still good, coils packs are good, wires good, new plugs, new crankshaft senor, new camshaft senor, still no fire
    used starting fluid and turned on, but ran rough, showed code and it said multiply random misfire
    any thoughts at what this could be
  2. #2 Re: still not firing
    Feb 2008
    Check to see if the fuel pump is coming on. What year and model is your car?
  3. #3 Re: still not firing
    Gaston
    yea its on, i have fuel pressure to the fuel injectors but they aint putting fuel out, i think it might be the ecm, but idk yet
    its a 2006 grand prix, base model
  4. #4 Re: still not firing
    Feb 2008
    If the injectors aren't firing, rent a NOID light set from AZ and see if they're getting a signal. If so, the injectors are dead (can happen from a voltage spike). If you're not getting a signal, check the wires through the harness. Could just be a ground wire loose.
    If all pieces check out individually, about the only thing left is the injector driver in the PCM.
  1. Firing order
    By TDCRacing in forum How To Write-Ups/Tech Tips
    Last Post: 06-10-2010, 12:31 PM
  2. not firing
    By jem0103 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-06-2009, 06:24 PM
  3. 06 gp not firing on 2-4-6 cyl
    By melnrob in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-14-2009, 05:19 PM
  4. engine not firing after UIM and LIM gasket replacement
    By Dericm02 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-03-2009, 02:30 AM
