Thread: Head Gasket? Or LIM ??
Results 1 to 14 of 14
  1. #1 Re: Head Gasket? Or Radiator?
    Charles City, IA
    Check your intake gaskets.
    SMGPFC Two Nipple General
  2. #2 Re: Head Gasket? Or Radiator?
    Donating Users chrisb's Avatar
    Bucyrus, OH
    The intake gaskets would be my first guess since thoses are a promblem on the 3800, and 3400. sure headgasket could cause it but is less likly. I would replace the lim gaskets if they have never been replaced yet and get the revised aluminum ones. (they are hard to find locally) zzperformance.com has them if you cant get them locally.
    If your doing this yourself You will need....
    1. Upper intake manifold gasket
    2. Throttle body gasket (normaly comes with UIM gasket). Also the throttle body doesnt have to come off.
    3. Lower Intake manifold gasket (Need black RTV should come with the gasket set)
    4. 10 quarts of oil. I like to change the oil right after replacing the gaskets. I let the car run for awhile untill i get air out of coolant system and if everything checks ok then i change it out once more just make sure no coolant/ dirt is in the oil. Spun bearings arnt fun
    5. coolant. good time to change the thermostat (need gasket for thermostat) and change to the green or yellow coolant! if you still run the orange dexcol s**t.
    6. somthing to clean the gasket surface with. scotch brite works good.
    That should be about it... there maybe more though.
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  1. blown head gasket
    By runn141 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-09-2009, 12:18 AM
  2. So.......Is it a head gasket
    By 04BlackComp_G in forum General Tech Discussion
    Last Post: 03-22-2009, 04:58 PM
  3. Possible Blown Head Gasket
    By Blk99GpGt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-09-2009, 12:40 PM
  4. head gasket?
    By Mikefisher in forum General Tech Discussion
    Last Post: 10-10-2008, 12:36 PM
  5. Possible Head Gasket?
    By msmenne17 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-12-2008, 10:44 PM
