Thread: Intake help
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 Intake help
    SE Level Member NickR's Avatar
    kennesaw, Ga
    i need to choose the right one for my car, 02 grand prix gt
    wut do u think?
  2. #2 Re: Intake help
    Outer Space
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: Intake help
    Jersey
    stick a filter on the end of the throttle body, problem solved
    16' wrx sti- stock
  4. #4 Re: Intake help
    Jul 2008
    Tampa, FL
    make one...period.
  5. #5 Re: Intake help
    kennesaw, Ga
    thats pretty cool, but i can just buy one, what is a good kind to buy?
  6. #6 Re: Intake help
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    x4 on making your own
    although if you absolutely HAVE to blow a bunch of money on something you dont need to, i recommend the wizaired intake from zzperformance.com
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  7. #7 Re: Intake help
    Donating Users blowfishRus6's Avatar
    g.a.
    doesent matter they all do the same thing
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  8. #8 Re: Intake help
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    does making one out of pipe and putting a good filter on the end really perform better then the stock one that is basically the same thing? im not bashing on the homemade or the ones that places make em im just interested because if they really help ill just have to make my own
    silver 2003 Grand Prix GT List is on it's way to be updated
  9. #9 Re: Intake help
    g.a.
    yes they are better. open and larger cone can inhale more air plus if you make a straiter tube that helps also.
    its slow.
  10. #10 Re: Intake help
    kennesaw, Ga
    yea actually that does sound alot better to make your own one that you know will work better. and also u may save alot more money
  11. #11 Re: Intake help
    Quote Originally Posted by NickR View Post
    Saving money and function is the real reason behind it. People get on here and ask wtf when we bash them after they buy a K&N Intake...$350 for the same thing that WORKS BETTER for $50 ish? You tell me
  12. #12 Re: Intake help
    kennesaw, Ga
    yea i get it actually so i guess im gonna make mine, is there anything you suggest i buy specialy for it?
  13. #13 Re: Intake help
    Outer Space
    I used 3" PVC and a Spectre cone filter (you can get them at auto parts store)
  14. #14 Re: Intake help
    SE Level Member J4pro2001's Avatar
    Crown Point, IN
    You have to worry about heat dont you? If you sick a open filter in your car your just sucking in hot air! Thats so bad for your car Bad MPG and even worse timing retard! Get one that comes with a box to block dout the heat! If you can afford it get the Wizaired Cold Air Induction System
  15. #15 Re: Intake help
    kennesaw, Ga
    thats wut anyplace would give you if you bought one for alot of money. just this way your making your own and saving alot of money
  16. #16 Re: Intake help
    Quote Originally Posted by J4pro2001 View Post
    you get better MPG with a hot air intake...unless you think phsyics dont apply to the world anymore.
  17. #17 Re: Intake help
    Nope. Anti-Science here.
    The Wizaird is junk. Don't waste your money like that guy probably did
  18. #18 Re: Intake help
    kennesaw, Ga
    hahaha anti science !
    yea im making my own thanks guys!
  19. #19 Re: Intake help
    Crown Point, IN
    If you suck hot air into your car your maf will tell it to retard the timing making it worse? Do you not have a maf on your cars?
  20. #20 Re: Intake help
    g.a.
    thats why you crame the filter into the fenderwell gotta watch out for dirt and stuff then tho.
    its slow.
  1. JMB intake
    By JB Miller in forum General Tech Discussion
    Last Post: 05-06-2009, 06:02 PM
  2. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
  3. intake
    By DDPeppa in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2009, 11:11 PM
  4. more on the intake
    Last Post: 02-25-2009, 09:29 PM
