Thread: Dented/Dimpled oil filter...
Results 1 to 5 of 5
  1. #1 Dented/Dimpled oil filter...
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    Ok, strange one... 98 GT, car has 148K on it... I've only had the car for about 3 months, did an oil change right after I got it, did another one last week. Last night I started tearing apart the suspension and noticed a dent in the oil filter after only a week. When I did the first oil change I noticed the dent also, but kinda figured it was the oil filter wrench that did it.
    The "dent" is located about 1/2" from where it mounts and is facing the outside towards the suspension. I guess a better word would be a dimple, it's not deep but something definately came up against it...
    Anyone else ever encounter something similar?
  2. #2 Re: Dented/Dimpled oil filter...
    Banned - Busted For Scamming
    Feb 2009
    is it bulged out or pushed in? if its bulged out, could be too high of oil pressure, stuck relief valve, if its a dent, could be a rock or something hit it from the road.
  3. #3 Re: Dented/Dimpled oil filter...
    Apr 2009
    Carlisle PA
    It's dented in, I was wondering about the rock thing also... Just seems weird that it was in roughly the same area on both filters.
  4. #4 Re: Dented/Dimpled oil filter...
    TDCRacing
    Guest
    You sure it was not caused by the wrench?
  5. #5 Re: Dented/Dimpled oil filter...
    I'd say get a cheapo filter and throw it on and see if it still happens...if not, probably a freak accident deal.
  1. Which oil filter?
    By Pontiacman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2009, 10:01 AM
  2. what filter is best?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-03-2009, 11:50 PM
  3. What K&N Air Filter To Use
    By SG2000GTP in forum General Tech Discussion
    Last Post: 06-01-2008, 06:00 PM
  4. Anyone have an S&B filter?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 04-12-2008, 07:18 AM
