Thread: L67 Top Swap on 05 L26
Results 1 to 20 of 24
  1. #1 L67 Top Swap on 05 L26
    Springfield VA
    I read the top swap FAQ, but i want to run this by you all since i am new to the GP world [ive owned mine for about 10 days]
    I have found a Guy parting out a L67 locally, it looks like he has everything for the top swap aside from the harmonic balancer and fuel rails/injecotrs.
    Heads $125
    Tensioner $20
    Idlers for Sc belt $25
    Coil Pack Bracket $35
    Lower Intake Manifold $60 it has the new metal gasket with only 2k miles on it
    Fuel Injectors
    Supercharger $120
    He said he'll do 275$ for everything.
    Sound like a good deal? and is there anything im missing [obviously ill need a harmonic balancer and the Fuel Rails/injectors]
    My GP is a 05 base model, and the GTP the engine is from is a 98 GTP, if it matters.
  2. #2 Re: L67 Top Swap on 05 L26
    TDCRacing
    Guest
    Your going to have to get your stuff from an 04+. Your car has a DBW Throttle body. Which will not bolt up to the Gen 3 supercharger. And even if it would the wiring harnesses are different for the 97-03 than the 04+
  3. #3 Re: L67 Top Swap on 05 L26
    GTP Level Member Scimmia's Avatar
    QCA, IA
    You could do it, but it would take some custom work for the tbody and PCV, some wire splicing for things like the injectors, and you would need certain parts, like the fuel rail, from an L32. As TDC said, I would find a setup from an L32, much simpler.
    2001 Buick Regal LS - Almost Stock
  4. #4 Re: L67 Top Swap on 05 L26
    TDCRacing
    Guest
    Quote Originally Posted by Scimmia View Post
    Hey what year did all of the grandprix's come supercharged? I thought it was 05 but I guess not. lol
  5. #5 Re: L67 Top Swap on 05 L26
    QCA, IA
    Quote Originally Posted by TDCRacing View Post
    Don't know, I didn't know there was a year like that. Pontiac screwed around with the names so much in 04+, and I never did figure it all out.
  6. #6 Re: L67 Top Swap on 05 L26
    Springfield VA
    The Fuel Rails and Injectors ill be getting from a 04+, or after market.
    what all is involved in modifying the TB to bolt up?
    i was planning on getting the parts from a 04+ or just going turbo, but for all the main components off a sub 80K engine for less then 300$ im really tempted to pick them up
  7. #7 Re: L67 Top Swap on 05 L26
    QCA, IA
    You would need an adapter of some sort. ZZP and other companies make one to go the other way, to put a L67 tbody on a Gen V, but I don't know anyone that makes what you would need. The existing adapters MAY be able to be modified to work, otherwise you'd have to get something made or make it yourself.
  8. #8 Re: L67 Top Swap on 05 L26
    TDCRacing
    Guest
    We can make you an apadter to work. It's just something that is not mass produced because it does not have a high demand.
    But you would have to countersink the Gen 3 holes and tap the Gen 5 holes. But other then that nothing.
  9. #9 Re: L67 Top Swap on 05 L26
    TDCRacing
    Guest
    Yeah. Me either. That's why I was hoping you'd know.
  10. #10 Re: L67 Top Swap on 05 L26
    Springfield VA
    if you could custom make an adapter that would be awesome, or if you know of any place with some more info on the adapter that would be useful as well.
  11. #11 Re: L67 Top Swap on 05 L26
    TDCRacing
    Guest
    Quote Originally Posted by Luda View Post
    I can. Just let me know.
  12. #12 Re: L67 Top Swap on 05 L26
    why would you put an l67 top on a series III..? just doesnt make sense to me. i would be doing an l32 top for sure.
  13. #13 Re: L67 Top Swap on 05 L26
    TDCRacing
    Guest
    Why not? Even if he was looking at getting the most out of his setup (HP wise) It's not that much of a difference. And another reason is you can't get a L32 top swap for 200 bucks.
  14. #14 Re: L67 Top Swap on 05 L26
    Springfield VA
    top swap, sans fuel rails, injectors, and harmonic balancer, for 200$. thats why im doing a L67 swap, i was going to go turbo until i found this local part out.
  15. #15 Re: L67 Top Swap on 05 L26
    QCA, IA
    Looking at your list, the only thing I see missing would be the valve covers.
    You're also going to have to plumb something up for the inlet of the PCV system, and figure out something with the MAP sensor, since your computer won't read a 2 bar sensor and there won't be a spot for your stock sensor. You do have a way to tune, right?
  16. #16 Re: L67 Top Swap on 05 L26
    Banned - Busted For Scamming
    Feb 2009
    if you dont have the valve covers, i can hook you up for cheap
  17. #17 Re: L67 Top Swap on 05 L26
    Springfield VA
    ill be getting a canned tune from ZZP for my base tune and then using a HPTuner from there, im talking with them about what all needs to be adapted on the PCM side to make it work.
    i didnt think about valve covers, but the guy has them so ill go ahead and grab them as well.
  18. #18 Re: L67 Top Swap on 05 L26
    Jersey
    It would be so much easier just to get an L32 top
    16' wrx sti- stock
  19. #19 Re: L67 Top Swap on 05 L26
    Springfield VA
    Quote Originally Posted by 99prixgt View Post
    yes, but much more expensive, and im not afraid of some custom fab work, or any tuning things.
  20. #20 Re: L67 Top Swap on 05 L26
    Good luck with that LOL
  1. L36 swap to a L26 ????
    By BILLJR71 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-16-2010, 09:49 PM
  2. What wil i need to do a top swap
    By gp3800t in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2009, 08:34 PM
  3. DIC swap
    By chrissbee77 in forum General Tech Discussion
    Last Post: 12-13-2008, 04:29 PM
  4. top swap
    By Grandprixboy1224 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2008, 04:23 PM
  5. DIC swap
    Last Post: 02-26-2008, 06:02 PM
