Thread: Newbie first time changing oil on 06 gp
Results 1 to 6 of 6
  1. #1 Newbie first time changing oil on 06 gp
    Michigan
    So this is my first time changing the oil on my Grand Prix, it's also the first time changing it on a transverse engine. What I believe to be the oil drain plug is on the side of the pan which I've not seen before. Also I can't seem to get the darn thing loose. My question is if the Oil pan drain plug should be on the side of the pan. (Note: I'm asuming I have the right pan because it's the only one with any kind of drain plug in it.) Or is the plug obscured by the oil filter (which would be odd.) Any help would be appreciated, I have had it changed before at a oil change place this last winter and I don't know if they put it on over tight or what. Also the space between the plug and another what looks like pan but has no plugs at all is so small I can't fit a socket wrench between it and have to use a 13mm wrence.
    Sorry for the wordy post and thanks for any help anyone can be.
  2. #2 Re: Newbie first time changing oil on 06 gp
    Barksdale AFB, LA
    It's on the "side" of the pan (closer to the rear of the car) so that you can lift the front of the car and have all the oil drain out better.
    I thought it used a 15mm wrench, but maybe it changed in later years. The other pan you're talking about is the tranny pan. Just put another wrench on the first one and get some leverage on that thing. If it's ever been taken to an quick change place they always over torque drain plugs.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Newbie first time changing oil on 06 gp
    Michigan
    Thank you, That's the pan I thought was right and yes it did go to a quick place with me twice over the winter (as my garage at the time had no power.) And I bought it used so who knows how many times then. I will just go out there and try and muscle it off. Thanks again for your help.
  4. #4 Re: Newbie first time changing oil on 06 gp
    Yup 15mm...oh...make sure the car isn't hot
  5. #5 Re: Newbie first time changing oil on 06 gp
    Michigan
    Well I dunno I used a 13 mm and it fit perfect the 15 was to big so I dunno if somewhere along the line it got switched with a different one or what..??.. ( I bought the car used.) Anyway thanks again.
  6. #6 Re: Newbie first time changing oil on 06 gp
    Huh, yeah...might have. Mine is a 15mm and so is all the other 3800 motors I have changed oil on...
  1. i need help on changing supercharger oil
    By Nos shottss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2009, 02:21 AM
  2. first time post long time car owner
    By penstar66 in forum Introductions/Noob Questions
    Last Post: 02-11-2009, 03:54 AM
  3. changing to a l67
    By srziemkowski in forum Off Topic Discussion
    Last Post: 02-10-2009, 09:44 PM
  4. Thinking of changing oil
    By GTP4 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2008, 04:00 PM
  5. Changing headlights
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 02-26-2008, 08:56 PM
