Thread: Fuel Pressure Regulator Help
Results 1 to 9 of 9
  1. #1 Re: Fuel Pressure Regulator Help
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Remove snap ring, remove with FPR with pliers in a twisting and pulling motion.
    Lube new one with vasoline
    Install in reverse.
  2. #2 Re: Fuel Pressure Regulator Help
    SE Level Member Latdogg's Avatar
    Great Falls, MT
    Quote Originally Posted by VinnieGTP View Post
    Install in reverse.
    How do I get that snap ring off? It looks like it should be easy to do, but I was having trouble with doing it yesterday. It looks as though you should just be able to pull that old one right out.
  1. Will this Fuel Pressure Regulator work?
    By Quicklynx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-30-2008, 09:25 PM
  2. Vacuum line for Fuel Press Regulator, where does it go?
    By 97grandprix38 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2008, 12:17 AM
  3. Fuel Pressure
    By RedGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2008, 10:53 PM
  4. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
  5. After Market Fuel Pressure Regulator
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2008, 02:14 PM
