Thread: Trottlebody space
Results 1 to 12 of 12
  1. #1 Trottlebody space
    SE Level Member Martin 04's Avatar
    Oct 2008
    queens
    i was looking at one from zz performance and its made for the 2004 and up but i dont know if it will fit on my gt since its not supercharged, does anyone know?
  2. #2 Re: Trottlebody space
    Barksdale AFB, LA
    Got a link? I don't see any that say they work on 04+ GPs.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Trottlebody space
    Oct 2008
    queens
  4. #4 Re: Trottlebody space
    Barksdale AFB, LA
    Oh, TB spacers. For some reason when you just put "space" in the title I thought you were talking about TBs and if the non supercharged had the space to fit one from a supercharged engine.
    No reason it should work on the N/A 04+. But, why are you getting one?
  5. #5 Re: Trottlebody space
    Oct 2008
    queens
    ya i thought i wrote spacer but i guess not, i wanna get the spacer and a CAI to try and make a little more hp but i since i cant find the spacer for a n/a i guess the CAI is all im gonna get for now
  6. #6 Re: Trottlebody space
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    This will not work on the N/A L36/L26 engine stock upper intake manifold or TB.
  7. #7 Re: Trottlebody space
    Las Cruces, NM
    No need for a TB spacer on a N/A. Get an HV3 instead from ZZP.
  8. #8 Re: Trottlebody space
    X2^^ HV3's are one of the best N/A mods hands down. After that try getting a PLOG and a 2.5" Downpipe...then maybe a Intake if you don't have one and a Ported Throttle Body...then a tune
  9. #9 Re: Trottlebody space
    Dec 2008
    Lawndale, CA
    You can get one of these.
    ZZ Performance
  10. #10 Re: Trottlebody space
    Barksdale AFB, LA
    Quote Originally Posted by The Guz View Post
    ZZ Performance
    Doesn't work on the L26, I don't think. I'm pretty sure the Series III engines use a four bolt setup instead of three like the Series II.
  11. #11 Re: Trottlebody space
    TDCRacing
    Guest
    Quote Originally Posted by Sabrewings View Post
    Correct.
    But you could use one of these.
    http://www.grandprixforums.net/f51/t...ter-11998.html
  12. #12 Re: Trottlebody space
    Oct 2008
    queens
    hey guys thanks a lot im buying the CAI in a few days and the hv3 will come soon after
  1. Total new system,, small space 2005 supercharged
    By scoobyydooooooo in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2009, 10:27 PM
  2. DVD player in empty space under hvac controls?
    By FockerNJ in forum Audio, Security & Visual Electronics
    Last Post: 04-20-2009, 05:18 PM
