Thread: Cooling Issue
Results 1 to 7 of 7
  1. #1 Cooling Issue
    SE Level Member armyrebel03's Avatar
    Little Rock, AR
    So I went to change out my water pump today, and just to be safe did a once over of the car. i found this:
    I replaced that and my thermostat, and the car seemed fine. I drove it home(about a 30 min drive) and the gauge read about halfway the whole time, it did go up about 2 notches above half, but came back down. Then, I had to go run an errand and the car started to overheat again, I didn't let it get to the red. It got about 1 line before the red before I shut it off. Do you think its still the water pump. or something else...
    2004 Grand Prix GT
  2. #2 Re: Cooling Issue
    did you bleed the air out of the system?
  3. #3 Re: Cooling Issue
    Kansas
    ^^^This.
    Also have you checked for leaks? are the coolant levels okay? Might be a faulty thermo even though it's new.
    SOLD 1999 GT Silvermist TS
  4. #4 Re: Cooling Issue
    Little Rock, AR
    Yes, I bled the system for about 30 min, and all levels look goos still, no leaks
    2004 Grand Prix GT
  5. #5 Re: Cooling Issue
    Kansas
    What thermo did you put in?
  6. #6 Re: Cooling Issue
    Little Rock, AR
    Stock replacement from O'reilly's, Murray Plus
    2004 Grand Prix GT
  7. #7 Re: Cooling Issue
    sounds like you have a persistant air bubble.
  1. 99 cooling fan issue
    By spidyrmen in forum General Tech Discussion
    Last Post: 04-23-2013, 05:04 PM
  2. Stumped on cooling fan issue
    By indy99gpgt in forum General Tech Discussion
    Last Post: 07-01-2012, 10:57 AM
  3. weird cooling issue
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2010, 05:44 PM
  4. A/C not cooling
    By VolsFan in forum General Tech Discussion
    Last Post: 05-16-2010, 08:54 PM
  5. Cooling
    By Davisgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2009, 07:30 PM
