Thread: ticking from inside the intake manifold!
Results 1 to 6 of 6
  1. #1 ticking from inside the intake manifold!
    Apr 2009
    Martinsburg
    Well as the title says I have a loud ticking sound coming from inside the intake manifold it only does it when I start it an will go away after the car reaches the normal temp. range. So about 5to10 min. was hoping some one on here can steer me in a good direction to what it could be an Thanks for any help guys!!!!
  2. #2 Re: ticking from inside the intake manifold!
    Banned - Busted For Scamming
    Feb 2009
    how many miles you have on it? youre lifters are probably just wearing out if its higher mileage, if not you could have a bad oil filter with a defective drainback valve in it.
    Logan
  3. #3 Re: ticking from inside the intake manifold!
    TDCRacing
    Guest
    Lifter(s)
  4. #4 Re: ticking from inside the intake manifold!
    Apr 2009
    Martinsburg
    116,579 is the mileage.
  5. #5 Re: ticking from inside the intake manifold!
    Feb 2009
    yea probably just lifters, if it really bothers you replace them, otherwise if it goes away they still pump up fine.
  6. #6 Re: ticking from inside the intake manifold!
    Apr 2009
    Martinsburg
    thanks guys for the info.
  1. Intake manifold :)
    By TheGreatGatsby in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-03-2009, 05:16 PM
  2. Lower intake manifold
    By FuglyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2009, 10:40 AM
  3. leaking intake manifold
    By chrizzle17 in forum General Tech Discussion
    Last Post: 01-09-2009, 11:30 AM
  4. Intake manifold
    By joesforspeed in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 12:15 PM
  5. Intake manifold
    By joesforspeed in forum Turbo
    Last Post: 10-21-2008, 03:55 AM
