SyntheticShield
There is one bolt on the resistor pack you can clearly see and clearly get to on the front side (closest to the glove box) and you have to completely remove it. There are two on the back side (closest to the firewall), one of which you should be able to see and one I doubt you will be able to. It is with these two that the flex shaft driver will come in handy. I would only LOOSEN them. Then you should be able to get the resistor pack out.
The two bolts you can see tighten back up when you install the new resistor. The third one (the one you cant see) I would encourage you to leave loosened. It will be a major major bear if you dont have a tool that can flex and get to those two back side bolts.
