Thread: Service Engine Soon P0140 P0118 P0113
Results 1 to 4 of 4
  1. #1 Service Engine Soon P0140 P0118 P0113
    Feb 2008
    West Jordan, UT
    Sorry to repost this, but I waited two days in the other section and nobody replied.
    This morning when I started the car, my check engine light came on. I got it scanned on the way home from school, and they pulled three codes.
    P0140 - o2 sensor
    P0118 - Coolant temp sensor
    P0113 - IAT sensor
    The coolant temp sensor was replaced about five months ago because the fans were not turning on unless the air conditioner was on. Replacing the sensor did not fix it, and I'm still driving it today with the same issue. A couple people were trying to help me with it, but people seem to have given up because we literally worked on this for months. But anyway, I'm wondering if this is an old code because when I'm driving the car a long distance I have to unplug the CTS which makes the fans stay on all the time or else the car will overheat. The check engine light always goes off a couple days after I plug it back in, but I don't know if it would still be pulling this code for that reason...
    The pre-cat o2 sensor is only about a year old. But I'm not sure which o2 sensor the code is referring to.
    The IAT code is new. Never seen that one before.
    And once again... The light just came on this morning.
  2. #2 Re: Service Engine Soon P0140 P0118 P0113
    SE Level Member Red97GPGT's Avatar
    grand rapids, MI
    Had these same set of codes. If you never cleared the codes after you pput the new parts in then you need to to that first. The problem with my car ended up being the EGR valve. The other possibilites could be the other O2 sensor or the IAT valve.
  3. #3 Re: Service Engine Soon P0140 P0118 P0113
    Feb 2008
    West Jordan, UT
    The o2 sensor has been replaced, but the car was never started without one. Does that still mean that it's an old code?
  4. #4 Re: Service Engine Soon P0140 P0118 P0113
    Feb 2008
    West Jordan, UT
    Come on guys... Nobody can help with this one?
  1. service engine soon
    By gp3800t in forum General Tech Discussion
    Last Post: 11-05-2009, 02:27 PM
  2. Service Engine Soon P0140 P0118 P0113
    By spenc938 in forum General Tech Discussion
    Last Post: 03-27-2009, 12:34 AM
  3. Blinking service engine soon light.
    By lutman123 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2009, 11:27 PM
  4. Service engine soon light
    By the955iman in forum General Tech Discussion
    Last Post: 02-15-2009, 01:21 PM
  5. Service Engine??
    By wrfdff4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2008, 11:55 AM
