Thread: How can i get cheap hp out of an 02 firebird 3.8 series 2?
Results 1 to 20 of 25
  1. #1 How can i get cheap hp out of an 02 firebird 3.8 series 2?
    indiana
    I want to get around 260hp or higher and i am at about 200hp
  2. #2 Re: How can i get cheap hp out of an 02 firebird 3.8 series 2?
    GT Level Member Merlin's Avatar
    May 2008
    Broken Arrow, OK
    Nitrous.
    Thats the cheapest way. Stick on a little dry 75shot and call it good.
    Engineering the impossible.
  3. #3 Re: How can i get cheap hp out of an 02 firebird 3.8 series 2?
    I live here. UR LOSN's Avatar
    Rockford, IL
    moved to L36 section......
    PCM tune, 1.9rr, SLP lid, Slp ram air intake, Borla/Corsa exhaust, bigger TB.... you will be dang close!
  4. #4 Re: How can i get cheap hp out of an 02 firebird 3.8 series 2?
    TDCRacing
    Guest
    Port work.
  5. #5 Re: How can i get cheap hp out of an 02 firebird 3.8 series 2?
    indiana
    What exactly is a 1.9rr, a TB, a slp lid, and slp ram air intake.
  6. #6 Re: How can i get cheap hp out of an 02 firebird 3.8 series 2?
    Nov 2008
    Chicago
    Quote Originally Posted by firebird92 View Post
    1.9rr=higher ratio roller rockers.
    TB= he means a bigger throttle body most likely
    SLP lid= ram air hood?
    slp ram air intake= doesnt need to be ram air
  7. #7 Re: How can i get cheap hp out of an 02 firebird 3.8 series 2?
    unless you switch to some form of forced induction (blower or turbo) youre not going to get much out of it unless you spray the crap out of it.
  8. #8 Re: How can i get cheap hp out of an 02 firebird 3.8 series 2?
    Oct 2008
    mascoutah, Il
    2002 GTP
    custom HOK paint
  9. #9 Re: How can i get cheap hp out of an 02 firebird 3.8 series 2?
    indiana
    none
  10. #10 Re: How can i get cheap hp out of an 02 firebird 3.8 series 2?
    May 2008
    Broken Arrow, OK
    Quote Originally Posted by Golgo13 View Post
    Don't send the kid to the playground with the retards.
    If you want real information go to
    FullThrottleV6.com - V6 Camaro, Firebird, Grand Prix, Mustang, and Challenger Tech Forums
    I will agree that 1.9s will do some good, but I've found on these cars that a TB is useless. The 02 cars have drive by wire and are un-portable. even if you did, and the motor went out on it, you have to throw it away. the cars intake flows enough air with the stock one anyway. after doing the bolt-on's your only inexpensive option is the juice.
    Knock out a lid and headers. (pacesetters are the cheapest alternative, but there are a set of longtubes that have put down some promising gains.)
    If you are talking about making 260 to the flywheel, this is very possible. If you are talking about to the wheels, you want to reconsider. The current n/a record stands at 275hp. your car without mods to it is about 170 to the wheels.
  11. #11 Re: How can i get cheap hp out of an 02 firebird 3.8 series 2?
    indiana
    i was hoping at least for 260 to the flywheel, and i was looking online and found turbo kits for around 600-800. would that be what i would need and would i have to uprgrade anything else?
  12. #12 Re: How can i get cheap hp out of an 02 firebird 3.8 series 2?
    May 2008
    Broken Arrow, OK
    you diddnt find kits anywhere for v6 f body's. Currently there are no bolt on kits avaliable. If you want one, however, Force fed fabrications can make everything you need.
    the only thing that i have found different between the gt and the f-bodys is the way they respond to tuning.
    I had my camaro tuned by Gary and if you are familar with the guy hes great at the gtp's, Has it down to an art. Unfortunately when we bolted the gtp's sc to the car, his tuning skills were no match for it. I ended up going to a good friend of mine and we shifted through it and sorted it out.
  13. #13 Re: How can i get cheap hp out of an 02 firebird 3.8 series 2?
    indiana
    whats the number for force bed fabrications? would that be expensive
  14. #14 Re: How can i get cheap hp out of an 02 firebird 3.8 series 2?
    Oct 2008
    mascoutah, Il
    Quote Originally Posted by Merlin View Post
    forgot about fullthrottle, oops
    2002 GTP
    custom HOK paint
  15. #15 Re: How can i get cheap hp out of an 02 firebird 3.8 series 2?
    Jersey
    turbo kit
    16' wrx sti- stock
  16. #16 Re: How can i get cheap hp out of an 02 firebird 3.8 series 2?
    GT Level Member Dohner's Avatar
    Montpelier
    Dose all these upgrade go for and 02 GP also or is it just for the Firebird?
  17. #17 Re: How can i get cheap hp out of an 02 firebird 3.8 series 2?
    Jersey
    Quote Originally Posted by Dohner View Post
    well you can't put the long tubes on, and we don't have drive-by wire throttle bodies that the 04 and up GP's have... but other than that we share the same motor as the v6 f-bodies.
    16' wrx sti- stock
  18. #18 Re: How can i get cheap hp out of an 02 firebird 3.8 series 2?
    Montpelier
    Sweet how much are bigger throttle bodies and do i have to upgrade anything else to support a bigger TB
  19. #19 Re: How can i get cheap hp out of an 02 firebird 3.8 series 2?
    Montpelier
    Holy crap only 600-800. Where did you find that deal at.
  20. #20 Re: How can i get cheap hp out of an 02 firebird 3.8 series 2?
    indiana
    on ebay but i dont know how quality they are( i dont know how to tell)
  1. 3800 Series II MPG?
    By PsychoGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2009, 12:40 AM
  2. Series 1 2 or 3?
    By ratnick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-04-2009, 08:08 PM
  3. Autometer Z series are fogging up
    By 99prixgt in forum Off Topic Discussion
    Last Post: 09-30-2008, 06:16 AM
  4. 3800 Series III 1/4 Mile
    By gp04 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-16-2008, 03:40 PM
