Thread: 3.8 engine idling rough-vibrating
Results 1 to 6 of 6
  1. #1 3.8 engine idling rough-vibrating
    Jul 2011
    midwest
    We have got a '97 GP with 182,000 miles that has started to cause some problems of late. The most recent one being a rough idle. You start the car and it sort of spits and sputters a little. When you put it in gear it almost dies, but never does. Upon acceleration it continues to run rough and sends a vibration through the whole car. It does seem to accelerate well still-just vibrates while doing so. If you pop it into neutral while at a stop sign and rev the motor it is more responsive, but when you drop it back into gear, it runs rough and almost sounds like it wants to die.
    Im thinking plugs and wires, but thought maybe someone here had similar situations and what they did to fix it.
    Thanks
  2. #2 Re: 3.8 engine idling rough-vibrating
    Florida
    Check engine light on? any codes? Could be just a needed tune up and bad mounts.
  3. #3 Re: 3.8 engine idling rough-vibrating
    St. Louis
    I would say plugs/wires, replace the fuel and air filter, clean the MAF and check for vacuum leaks then see what you get.
    Just stick w/ stock plugs and wires. No need to get super duper quintillion platinum plugs. I personally run NGK V-Power TR55's and have yet to have and issue. Also stock Delco wires from the dealer.
  4. #4 Re: 3.8 engine idling rough-vibrating
    Jul 2011
    midwest
    No che engine light is on. Still expoloring my options. Discovered earlier today a hissing noise coming from the dipstick. It is almost like a vacuum is screwed up and drawing air through the dipstick. I took the oil cap off while running and it was like a big sigh of releif came from the motor grasping for air. It is pulling air in through the oil cap when removed. I drove with the cap off for a while but it did not change anything. The engine is still rough running and vibrates upon acceleration. Still stumped and looking for options.
    Thanks
  5. #5 Re: 3.8 engine idling rough-vibrating
    Change the pcv valve. ensure you get the o-ring back on the new one.
  6. #6 Re: 3.8 engine idling rough-vibrating
    GT Level Member fremmy182's Avatar
    Center Moriches, New York
    yeah i kind of have the same problem with the vibrating when a stop light and upon acceleration. I still havent fixed the problem but i just ordered shorter dog bones and going to replace lower motor mount and trans. mount and see what that leads to.
  1. engine idle rough, acceleration bad
    By ksredryder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-30-2010, 08:30 AM
  2. Engine running rough?
    By 05PontiacGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-21-2010, 06:04 PM
  3. rough engine then wont start
    By RyanL in forum General Tech Discussion
    Last Post: 06-06-2010, 03:32 AM
  4. rough idle after engine swap
    By almighty in forum Engine
    Last Post: 11-18-2009, 06:25 PM
  5. engine idling high
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2009, 11:49 PM
