Thread: Fuel Injectors Leaking?
Results 1 to 9 of 9
  1. #1 Fuel Injectors Leaking?
    Jan 2009
    Western Ontario
    Well after a new fuel pump and UIM my old GP is running pretty well. However when I shut it off and go to restart it (warm restart, 20 or 30 mins later) it does alot of cranking (10 to 20 seconds) b4 it starts.
    Sometimes I can smell gas, and the oil level has risen about 1/2 a liters in 2000 kms.
    This car has 265000 kms on it, Just wonder do injectors go bad and start to leak? (familar with this in Diesel mechancal injection) How does one test them and should I change them all?
    Ken
  2. #2 Re: Fuel Injectors Leaking?
    TDCRacing
    Guest
    When you pull the injector's out you can see that they have rubber o-rings on them. This is what actually seals them. If they are leaking you need to go to the parts store and pick up some new ones and install them.
    Problem solved.
  3. #3 Re: Fuel Injectors Leaking?
    Barksdale AFB, LA
    Quote Originally Posted by TDCRacing View Post
    Problem solved.
    It is possible for them to leak internally.
    You could easily check them by doing a fuel pressure test. Though, I'd suspect your FPR is leaking before one of the injectors.
    2009 Subaru Impreza WRX STI
  4. #4 Re: Fuel Injectors Leaking?
    TDCRacing
    Guest
    Quote Originally Posted by Sabrewings View Post
    Sounds like there doing their job then. As long as they leak at the right time...
    Just kidding, I know what you ment.
  5. #5 Re: Fuel Injectors Leaking?
    Barksdale AFB, LA
  6. #6 Re: Fuel Injectors Leaking?
    Jan 2009
    Western Ontario
    Yeah, it not a vaccum leak, its fuel getting into the engine when it should'nt
    I guess if I pulled the fuel injectors and pressured up the system buy turning the key on if and a injector is bad I'd see it drip?
    New one are over $100 each so changing all 6 just incase it out of the question.
    How would you test the fuel pressure regulator??
    I have to check the price on this, if it not too bad just buy one.
    Ken
  7. #7 Re: Fuel Injectors Leaking?
    Nov 2008
    Chicago
    If its an external leak you should be able to use some starter fluid to test. Spray the fluid around the injectors and if you notice a difference, youve got a leak.
  8. #8 Re: Fuel Injectors Leaking?
    TDCRacing
    Guest
    Quote Originally Posted by skidsteer View Post
    Ken
    FPR should be about 20 bucks. PM sent.
  9. #9 Re: Fuel Injectors Leaking?
    Nov 2008
    Chicago
    autozone would prolly rent a fuel pressure guage for free.
    To see if your FPR is shot, take a pair of pliers and pinch the return fuel line so it builds up pressure in the line.
  1. Large EVAP LEAK and FUEL CAP LEAKING?????
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-19-2008, 12:55 PM
  2. fuel line leaking
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 03:08 AM
