Thread: Rad question
Results 1 to 6 of 6
  1. #1 Rad question
    Feb 2009
    everywhere
    hey i just installed a new rad , i dont see any leaks so far except one the temp sensor ( i think thats what it is ). yea i got a steady drip coming from there when i took it from the old one it just had some wire a round it how can i stop the leak would the red gasket maker stuff work ? should i buy a new one ? it still works i mean it read the temp fine but i dont like the drip
  2. #2 Re: Rad question
    TDCRacing
    Guest
    You can use pipe tape or any color RTV.
    My preference is the gray high temp RTV.
  3. #3 Re: Rad question
    I live here. UR LOSN's Avatar
    Rockford, IL
    they Grey works good. I used a liquid Teflon tape paste.....
  4. #4 Re: Rad question
    GT Level Member GPSims39's Avatar
    Nov 2008
    Hauppauge, NY
    I have a small pin hole in the plastic top part of my Rad, i can see a small stream pissin out when the car is up to temp, im thinking about using some plastic weld epoxy it can handle 1300PSI and 250+ Temps im hoping it will work, what you guys think?
  5. #5 Re: Rad question
    TDCRacing
    Guest
    I'm not so sure 1300 psi can come from a hole that big. I would try some JB weld if it's only a pin hole. Just ruff it up real good.
  6. #6 Re: Rad question
    Nov 2008
    Hauppauge, NY
    ok doing it on lunch, since it takes 15 min to set and i got another 5 hours to go till i leave now woudl be a good time, cross your fingers cant affort a new rad
