Thread: misfiring?, hesitating? valve lash?
Results 1 to 2 of 2
  1. #1 misfiring?, hesitating? valve lash?
    SE Level Member icolex1's Avatar
    Feb 2009
    Highspire,PA
    I just finished a head gasket change on the 3800 from my '02 GP, did the LIM and a new plenum and gasket. thought I had a vaccum leak because of sputtering, checked that out with som carb cleaner, everything is good in that aspect. just took it down the road and it pops and sputters, any ideas ? thought maybe valve lash? Haynes manual said to torque to specs. is it possible the rods are not seated properly, I can't see how though..
    It seems simple and please correct me if I wrong:
    torque the head
    put the rod guide in
    insert the rods in same place they were in
    torque the rocker arms (in the same place they were in) to spec
    any ideas?
    I need some help guys!!
    hydro-powered
  2. #2 Re: misfiring?, hesitating? valve lash?
    Feb 2009
    Highspire,PA
    just got it fixed, as usual the easy things are what I over look.
    problem: loose spark plug wire! (I'm an idiot)
    thanks for looking though
    hydro-powered
  1. Valve Lash
    By kissmyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-31-2009, 06:49 PM
  2. valve lash.
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-30-2009, 08:43 AM
  3. Misfiring?
    By hotshot in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-05-2008, 09:33 PM
  4. Hesitating shifts
    By Andrew_99GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2008, 01:03 PM
  5. Help!! '01 GTP misfiring/idiling rough at startup!!
    By fatride99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2008, 06:20 PM
