Thread: Evap leak
Results 1 to 6 of 6
  1. #1 Evap leak
    Nov 2020
    Michigan
    Had a check engine light on and so I went to the auto store and they said that the code is showing a EVAP leak. Is that an easy cheap fix? My information screen does say on occasion to check gas cap. The auto parts guy suggested to WD40 the gas cap gasket and to scotch bright around the gas port (it had some surface rust on it)
    Any other suggestions?
  2. #2 Re: Evap leak
    if its the p0455 code, thats a large leak. if your in the rust belt look under the car where the gas fill tube is, theres the fat gas in tube, then a smaller vent one. mine rusted out causing that code. you can also look for busted plastic lines to and from the evap solenoid under the hood.
  3. Likes RobVandal liked this post
  4. #3 Re: Evap leak
    Nov 2020
    Michigan
    Shoot, i didn't note the actual code that was being tripped. Thank you for that information! That helps a lot.
  5. #4 Re: Evap leak
    May 2020
    Pittsburgh
    evap purge solenoid (under hood, typically on the egr bracket, hose goes to just behind the throttle body) is closed until commanded open. it's easy to test.
    disconnect the purge valve connector, let the car run, and take off the hose that goes to the tank. if you have vacuum coming out of the purge valve, it is stuck open and will cause an evap code and sometimes a lean code (P0171) as well.
    aside from that and visually inspecting the gas cap seal, it's hard to determine without having access to the undercarriage or a smoke machine.
  6. Likes RobVandal liked this post
  7. #5 Re: Evap leak
    GT Level Member mguzzo's Avatar
    Buffalo NY
    could also be pinholes from rust in the gas filler neck
    agree with above, a smoke machine is really what's needed to find the small leaks
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  8. #6 Re: Evap leak
    Sep 2020
    I had the same code I believe on my '06. I pulled the driver rear wheel well liner and saw that the purge cannister was bloated and cracked. For me, that made troubleshooting really easy. Might want to check it out.
  1. EVAP Leak
    By WootyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2016, 07:57 PM
  2. Evap Leak
    By gordster1122 in forum General Tech Discussion
    Last Post: 01-16-2015, 10:10 PM
  3. Evap leak and surging in 4th
    By vtechkiller in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-20-2012, 01:53 PM
  4. Evap system leak in '06 GXP
    By GPGXP06 in forum 5.3L V8 (LS4)
    Last Post: 06-13-2012, 10:30 AM
  5. evap leak need help
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2011, 08:58 PM
