Fans are not coming on. Changed coolant sensor. With ac or heater on driver side or left hand side fan on at any temp. check engine light on after clearing twice code p1651. At 210 * with power jump to Cooling fan relay at 87 blows 15 a fuse when powered. With power to 87a cooling fan relay driver side fan on. At 210* cooling fan 1 relay 85 jumped to 86 driver side fan on and passenger side on but a little slower. At 210* CF1 relay and power to 30 both fans on passenger side or right side a little slower. CF2 relay power to 87 driver side fan on high and cf1 jumped to get LH or passenger fan on high too, nothing on LH fan and ds still runing. Tested relays all good, changed them all no difference. I need to fix for smog check this month please help. What bi directional scanner would be best for 98 pontiac and 97 suburban? I need to command fans on with scanner to check pcm? I'm thinking short on pcm to relay but i can get everything to work scratching head? Left hand is passenger side? Short at 87 on CF relay because fuse blows? PCM bad? PCM commands at with ac and heater on? I can get low speed fans on but no high speed fans if I power or jump. Only one hi speed fan on jump.
@ 210* Cooling Fan Relay pin 87=.0 v, 87a=0.0 v, 86= 12.5 v, 85= 12.5 v, 30=0.0 v.
@ 210* Cooling Fan 1 Relay pin 87=12 v, 86=12 v, 85=0.4 v, 30= 0.0.
@ 210* Cooling Fan 2 Relay pin 87=0.0, 86= 12 v, 85= 12 v, 30= 12 v.
