Thread: Transmission
Results 1 to 4 of 4
  1. #1 Transmission
    Dec 2018
    Atlanta
    My transmission be working perfectly fine but the more i ease on the gas the transmission would slip and start shifting rough also when I turn left alot. Whats the cause of this issue??
  2. #2 Re: Transmission
    St. Louis
    Wipe the trans. dipstick on a clean white cloth and see what the color is. If it's still red or red-ish then no problem.
    Check the fluid level while the car is fully hot, in park, running. If it's not full then top it off.
    When was the last time a fluid/filter change was done? How many miles on this trans?
  3. #3 Re: Transmission
    Left turn slipping is typically low on fluid.
  4. #4 Re: Transmission
    Jul 2017
    macomb mi
    yep exactly my case in my first year of college lucky I took all the winding roads home turned out my transmission lines were leaking real bad drove on it for a few more weeks before changing them since I didn't have a place to do the job and weather was terrible but went through a ton of fluid haha definantly make sure its filled up before driving it again I remember mine being scary low when I checked it after it was slipping on left turns but good news is my same trans is still strong today 2 years and about 65k miles later ive added a trans cooler and shift kit since I was seeing temps of 220+ degrees in the winter but that's all ive done to the transmission the whole time owning it.
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  1. 2004 GTP transmission vs GTP Comp G transmission
    By Jordan in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-06-2014, 12:33 PM
  2. Transmission went out :/
    By jakobkay in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-26-2013, 05:31 PM
  3. Transmission????
    By GrandPrixboi504 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-18-2011, 08:53 PM
  4. Did my transmission just die?
    By SliceTheRice in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-17-2011, 12:45 PM
  5. transmission
    By jhlbigblock454 in forum Introductions/Noob Questions
    Last Post: 04-06-2009, 02:40 PM
