Swap #5 plug and wire with another and see if the misfire moves to the other cylinder. If so, bad plug or wire. If not, try swapping ignition coils too. Could also be #5 fuel injector, so you could try swapping injectors after that if the ignition components turn out to be good. Just start with the easy, common stuff and move on from there.
