Thread: Seeking a write-up for Water Pump Removal & Replacement
Results 1 to 4 of 4
  1. #1 Re: Seeking a write-up for Water Pump Removal & Replacement
    break free the 4 pulley bolts in the water pump pulley, then take the belt off, then take the power steering pump off, then take the water pump bolts out, the 4 long bolts, coolant will come out these holes, its normal. you want to use some thread sealant on these 4 bolts when re installed. clean the timing cover well. use a new dry gasket, make all your bolts tights and your done. get your belt back on and then make the 4 little pulley bolts tight.
  2. #2 Re: Seeking a write-up for Water Pump Removal & Replacement
    Feb 2019
    US
    It's actually very easy. We took the bolts off the coolant reservoir and moved it out of the way, then took the alternator off because it was in the way. Iirc, that was the only extra work required. Once those two things are out of the way the pump is pretty accessible. You may need to remove your passenger side wheel for easier access to the bottom bolts, and I recommend either getting Gates or Dorman metal coolant pipes to replace the plastic ones while you're swapping the pump.
    Sent from my LM-G710VM using Tapatalk
  1. Water Pump Removal
    By MattF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-05-2013, 11:40 AM
  2. Replies: 1
    Last Post: 04-22-2013, 11:32 AM
  3. HELP!! water pump removal
    By tmackster in forum General Tech Discussion
    Last Post: 03-13-2012, 12:45 AM
  4. Help 2001 Grand Prix water pump removal
    By prosecho in forum General Tech Discussion
    Last Post: 09-12-2009, 09:47 PM
  5. 60 V6 Engine Water Pump Removal And Install [*]
    By 19SE92 in forum How To Write-Ups/Tech Tips
    Last Post: 03-09-2008, 09:15 AM
