Thread: Gauge cluster dies when put in drive
Results 1 to 5 of 5
  1. #1 Gauge cluster dies when put in drive
    Jul 2018
    US
    My girlfriend's 04 gp is a bit rough around the edges but she loves it. Right now its its biggest problem is that the gauge cluster works when started cold, but when its shifted into drive (only drive reverse and neutral do not affect it) it totally dies except for backlighting. If its shut off and immediately restarted its still dead, but if left for 20+ minutes it works again only to die when put into drive. Its also running rough and smells rich, though I'm unsure if those are related problems as they started at different times. If anyone could offer some ideas i would appreciate it, ive steadily been doing repairs that are possible (and still needed) repairs for the all around issues but im not having much luck.
    Sent from my SM-G965U using Tapatalk
  2. #2 Re: Gauge cluster dies when put in drive
    That's an odd one. Try pulling the cluster and ensuring a good connection at the back of it.
  3. #3 Re: Gauge cluster dies when put in drive
    St. Louis
    When was the last time it had plugs and wires changed? Clean the MAF and throttle body? Change the air filter? If the answer to any of those is "I don't know", then do it. You say you are doing repairs but didn't say exactly what you've done. Some specific info would go a long way. Also, is the check engine light on? How many miles on the car?
  4. #4 Re: Gauge cluster dies when put in drive
    Jul 2018
    US
    A full tune up has not been done. Shes had it about a year now and bought it from her uncle. He claims he did a complete tune up on it just days before she picked it up. So far we have replaced both radiator hoses, fuel filter, gauge cluster, new air filter (i work in an oil shop so my first move was a full service oil change) trans filter and flush (she did that on her own) radiator flush (before hose replacement), ive done a MAF check on it and it didn't affect how it ran.
  5. #5 Re: Gauge cluster dies when put in drive
    Jul 2018
    US
    Also its got close to 200,000 on it and when the codes are ran it gives me a "random multiple misfire" code, an ABS code and an airbag code.
  1. Gauge cluster fix???
    By 92GPcoupe in forum General Tech Discussion
    Last Post: 02-28-2013, 06:02 PM
  2. le gauge cluster fuel gauge dnt work
    By cliffdawg in forum Visual/Body Modifications
    Last Post: 11-21-2011, 08:50 PM
  3. Swapping a 3 gauge cluster for a 6 gauge cluster
    By knoppsicle in forum General Tech Discussion
    Last Post: 10-16-2011, 09:49 PM
  4. 05 GP Gauge Cluster
    By RegorHtims in forum Audio, Security & Visual Electronics
    Last Post: 07-08-2011, 06:43 PM
  5. Engine Dies in Drive
    By crusingtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2010, 10:38 AM
