Thread: Broken coolant elbow, part inside engine
Results 1 to 4 of 4
  1. #1 Broken coolant elbow, part inside engine
    GT Level Member firstdue's Avatar
    Toledo, Ohio
    Ok, i finally got around to doing my elbows on my 100,000 2001 GT. Everything is going good until the first elbow just under the intake breaks apart...and the rest of it is not in the opening. The other 3 spots i had to pry out the broken ends of the elbows. Should i worry about the piece inside? I hadn't planned on doing the LIM or UIM gaskets yet.
    THANKS!!
    2009.1 Liquid Red G8 GT
    2001 Grand Prix GT Bright Red
  2. #2 Re: Broken coolant elbow, part inside engine
    ive heard of this and people just let it go. you might be able to fish it out with some wire, but thats gonna be a task of luck, no skill needed there. you either get lucky or dont when fishing lol
  3. #3 Re: Broken coolant elbow, part inside engine
    Toledo, Ohio
    Thanks for the super fast reply!!
    I did just leave it.
    Sent from my SM-N910V using Tapatalk
  4. #4 Re: Broken coolant elbow, part inside engine
    St. Louis
    When something like that happens I usually grab my trusty coat hanger and put a dab of RTV on the end of it then fish it through. Usually will pick up small pieces no problem.
  1. coolant elbow broken only 5 months old..?!?!?
    By jdmgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2013, 09:34 AM
  2. coolant elbow broken inside engine
    By bjlandt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-28-2013, 09:18 AM
  3. Any ideas? Broken coolant elbow won't come out of water pump..
    By CRU1Z3R in forum General Tech Discussion
    Last Post: 04-27-2012, 05:04 AM
  4. Broken coolant hose (elbow)
    By kking89 in forum General Tech Discussion
    Last Post: 09-29-2011, 10:34 PM
  5. coolant elbow broken, will not come out.
    By kingfish in forum General Tech Discussion
    Last Post: 02-26-2010, 08:17 PM
