Thread: Car smells like gunpowder
Results 1 to 20 of 21
  1. #1 Car smells like gunpowder
    Mar 2018
    Indiana
    Hey y'all I've got an 02 that's been sitting for roughly 5 months. I went to start it and the battery was dead so I slapped a new one in and now it will start and run for about .8 seconds and shut itself off. If I get on the gas I can keep it running but barely. It won't go over 4k and it sounds like it's missing. I did find a short in the #2 plug wire so I changed the ICM, all of the coil packs, ignition wires and plugs. But none of that helped. I checked the fuel pressure and it's fine so the pump and filter are ok. Also i hook up a code reader to erase codes and I can't get a connection to the engine. And to top all of that off when I keep the accelerator down the exhaust smells like gunpowder. I NEED HELP
  2. #2 Re: Car smells like gunpowder
    SE Level Member BANDIT's Avatar
    Ontario, Canada
    Do you have critters living in your air filter, where was it left sitting?
    04 GP GT Bone stock, just like me! 09 G8 GT...oh yeh!!!
  3. #3 Re: Car smells like gunpowder
    Mar 2018
    Indiana
    It was left outside but no I checked the air box and saw no signs of critters I also reseated the pcm while I was in there
  4. #4 Re: Car smells like gunpowder
    Mar 2018
    Indiana
    I also did some reading and saw a lot of things saying it could be the cat and I don't much care if it's loud so I cleaned out the cat and still nothing
  5. #5 Re: Car smells like gunpowder
    St. Louis
    Check the cigarette lighter fuse. Believe this is tied to the OBD port as well. Also check fuse #21 (i think). This should be for the MAF sensor. If you're trying to rev it that high in park its likely hitting the rev limiter.
  6. #6 Re: Car smells like gunpowder
    Mar 2018
    Indiana
    Just check them both theyre both ok
  7. #7 Re: Car smells like gunpowder
    Mar 2018
    Indiana
    Just put the old ICM back in and now I have connection to the engine but imm not getting any codes and it still won't run. I have a security light flashing. And I know my dad's Denali had issues with the security shutting the car off so I wondered about that but I wouldn't be able to keep it running if that were the case right?
  8. #8 Re: Car smells like gunpowder
    Mar 2018
    Indiana
    Ok now I have a P0650 code and ideas on what could be causing it?
  9. #9 Re: Car smells like gunpowder
    Mar 2018
    Indiana
    Also i just remembered my wife drove it a while back and said that all of the lights would just randomly shut off and then come back on
  10. #10 Re: Car smells like gunpowder
    St. Louis
    Does the Check Engine Light in the cluster light up at startup? If not, then a blown bulb can throw that code. Also, check ALL the grounds, especially the one under the ICM. Make sure they and both battery termianls are clean and tight. I've had a loose battery cable cause strange things like this.
    Do you have another key to try?
  11. #11 Re: Car smells like gunpowder
    key off unplug the maf sensor. then try to start it up.
    defiantly on the rev limiter in park revving it.
    like ford said. key to on, the cel on? if not the clusters bulb is out.
    scanner can connect is the fuse like ford also said up there. power port fuse, no idea wtf # it is.
    did you say pcm swap? or icm. think i seen both. pcm swap you need to do a security learn if you changed the pcm. key to run for 10 minutes, then off for less then 10 seconds, repeat 2 more times, 4 th turn of the key it should crank and run.
  12. #12 Re: Car smells like gunpowder
    Mar 2018
    Indiana
    Where does it ground on the ICM? It's definitely grounding at the battery I made sure of that. And I can't try another key the one in it is snapped off in the ignition cylinder. It's been like that since I bought it 7 years ago
  13. #13 Re: Car smells like gunpowder
    Mar 2018
    Indiana
    I said ICM. My brother has an identical car that he is scrapping can I swap the PCM from his car? And if I do that do I still have to relearn it
  14. #14 Re: Car smells like gunpowder
    icm ground is on its harness, not directly on the icm.
    yes you can swap the pcm. if you have a dead key then you need to do that security learn deal. you got a 50/50 shot it will just crank and run off it. if the osid # for the OS is the same it will. but you really have no way of seeing that.
    check your fuel pressure too. or at least hit the valve on the fuel rail. key on, gas should spray out with force, no pressure and nothing or very little will come out.
  15. #15 Re: Car smells like gunpowder
    Mar 2018
    Indiana
    I already checked fuel pressure it was good
  16. #16 Re: Car smells like gunpowder
    id take your brothers dash cluster too. as long as his cel light come on when the key is to run, solves that issue.
    swap his maf in there too. check that fuse 21 iirc is good, thats the maf's fuse.
  17. #17 Re: Car smells like gunpowder
    St. Louis
    The ground on the ICM attaches to one of the studs that holds the ICM mounting bracket to the head. Small black wire with a toothed ring terminal end on it. Should come out of the harness that also connects to the ICM itself.
  18. #18 Re: Car smells like gunpowder
    Mar 2018
    Indiana
    What are the chances it could be a cam pos sensor or crank pos sensor?
  19. #19 Re: Car smells like gunpowder
    mice eat wires of stored cars. zrsrt checking over the harness.
  20. #20 Re: Car smells like gunpowder
    Mar 2018
    Indiana
    I got it. I pulled the fuel rail off to make sure all injectors were working they all seemed fine I put the rail back on and now it runs fine
  1. O what smells?
    By Koba23 in forum Introductions/Noob Questions
    Last Post: 01-05-2015, 10:50 PM
  2. oil smells like gas
    By nicks98gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2011, 07:48 PM
  3. oil is overfull and smells like gas???
    By shawn3091 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2010, 02:58 PM
  4. Smells like FIre
    By chitownballer8908 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-13-2009, 07:06 PM
  5. Help!! 2004 Comp G Smells
    By dnnschuett in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 09:16 PM
