Thread: Which cat is better
Results 1 to 14 of 14
  1. #1 Which cat is better
    Feb 2018
    Canada
    Hey gang. I have an 08 na 3.8l with 225 000 kms and I need to replace the cat.....again. I bought a walker cat but this time I'm thinking of spending more and buying the bosal cat. Just wondering if anyone used it on here andy how it worked out. I DO NOT WANT TO DO THIS AGAIN lol. But serves me right I guess cuz when I did my lim I didn't torque to it to spec and didn't goop the corners which killed the 1st one.
    Thanks
  2. #2 Re: Which cat is better
    The Boss Iceman6669's Avatar
    Jun 2011
    Best cat is no cat...
    2011 F-150 Yote powered
  3. #3 Re: Which cat is better
    you would need a stock replacement or you'll get a cat code.
    whats wrong with the one you got now? cant see no rtv in the corners of a lim killing a can. they need to run pig rich to kill one fast.
    if you have a high flow cat now, thats the issue i bet. cars not gonna like that hi flow cat.
    you got a code for a cat?
  4. #4 Re: Which cat is better
    I think he means the engine was burning a lot of coolant with a improper install of the LIM. Lots of coolant or oil burning will wipe out the converters faster than some think.
  5. #5 Re: Which cat is better
    Feb 2018
    Canada
    The cat is plugged from coolant andy a ridiculous amount of oil being burned by the lim job done wrong. The can't get the car over 3500 rpm. I just want cheapest fix possible. But yet I need it work right. If I delete the cat amd get a code would that effect gas mileage and overall performance of the engine?
  6. #6 Re: Which cat is better
    Feb 2018
    Canada
    And yes I'm getting a code. 420 for cat. I plan on keeping it till I scrap it so want to do the right thing.
  7. #7 Re: Which cat is better
    Yes, no cat will always cause a code and poor mileage in your year car.
    I say either cat will work, a new walker or the bosal cat. Both have warranties too.
  8. #8 Re: Which cat is better
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    I bought a ebay high flow cat and use the spark plug nonfouler trick to pull the 02 sensor out of the exhaust stream a little to not get a light.
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  9. #9 Re: Which cat is better
    Jul 2010
    Coquitlam,BC,Canada
    Just shy of 6 years of use, and still doing its job.....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  10. #10 Re: Which cat is better
    damn fools put a U bend in it, that blows.
  11. #11 Re: Which cat is better
    Jul 2010
    Coquitlam,BC,Canada
    That's the only way to call it OE replacement. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  12. #12 Re: Which cat is better
    Enfield, CT
    yep that's why i went with a bosal one once. no u-bend. I've been running a zzp cat-less downpipe for years and I love it cause I'll never have to worry about a cat again. Obviously I have a tune to eliminate the light along with other things.
  13. #13 Re: Which cat is better
    The u-bend in the aftermarket ones do not get as small as the factory pipe though, they kept the design so the o2 sensor would fit in the same spot.
  14. #14 Re: Which cat is better
    Mar 2018
    NY
    Can't speak for Walker or Bosal cat converters although I can tell you Bosal did make the factory catback for our cars (at least on the Grand Prix GT/GTPs). From my personal experience though I used the cat that came with the SLP headers. The first one lasted about 2 years. The 2nd one lasted about 6 years. After that 2nd SLP cat I couldn't find anymore available out there so I went with a Magnaflow hi-flow universal cat. I've had that one about 5 years so far no issues. The aftermarket units are kind of a mixed bag. I would go with one that has a better warranty
