use your multimeter set to resistance (Ohms) and measure from pin 69 on pcm to pin on maf connector. If it reads OL or zero, there's a short. If it reads a small value, the wire is continuous (good). Then your options would be to either measure the frequency of maf sensor with a good multimeter, replace maf sensor, or conclude that there is a fault in the pcm and replace it
