Thread: Shift kit spacers
Results 1 to 10 of 10
  1. #1 Shift kit spacers
    Jersey
    I'm putting a Transgo shift kit on my 97 gp but the spacers doesn't fit onto the pins. The pins are bigger than the spacers. This is first time I've been in the transmission. I'm so confused and car is on jacks with no other way of transportation. Could it be that the last owner was in here before me??
  2. #2 Re: Shift kit spacers
    Jersey
    <a href="http://s349.photobucket.com/user/aoliver4mayor/media/IMG_20170825_120616_zpszhi7afxj.jpg.html" target="_blank"><img src="http://i349.photobucket.com/albums/q384/aoliver4mayor/IMG_20170825_120616_zpszhi7afxj.jpg" border="0" alt=" photo IMG_20170825_120616_zpszhi7afxj.jpg"></a>
  3. #3 Re: Shift kit spacers
    Drill the spacers larger so they fit.
    Haven't had that issue before but it's not a huge issue if you have a drill.
  4. #4 Re: Shift kit spacers
    Jersey
    Ok let me charge it up
  5. #5 Re: Shift kit spacers
    Jersey
    Does anyone know if I can order a spring for the 2-3 accumulator for the top of the piston? Mines was missing when I popped the accumulator open smh. I need a part number would be appreciated.
  6. #6 Re: Shift kit spacers
    Dec 2013
    Enfield
    What is the part number of the Transgo you are installing? I wouldn't drill anything, if its not right send it back. Stop into any local transmission shop and explain what you have going on. Sounds like more going on in there and someone could have done something wrong before. Take lots of pictures also. These shift kits are super easy to install, if need be put it back together until you have the correct parts.
  7. #7 Re: Shift kit spacers
    SE Level Member 1FastGP's Avatar
    May 2015
    Indian Trail, NC
    Another note seeing as how it is a 97, if your car is not a GTP it has a 4t60e vacuum actuated tranny. It was a 97 model year only thing on SE and GT so if your trying to install a 4t65e shift kit in it that is most likely your problem with nothing fitting.
    Sent from my SM-G955U using Tapatalk
  8. #8 Re: Shift kit spacers
    Dec 2013
    Enfield
    This ^^^. Good catch and most likely the correct answer.
  9. #9 Re: Shift kit spacers
    Jersey
    Damn didn't think about that. Its a 97 se but it has the 3800 engine in it as it was an option during that time of production. I'll look for markings on the tranny to confirm if its a 4t60e
  10. #10 Re: Shift kit spacers
    Jersey
    On a side note..I did put in the better springs that came with the kit...probably isn't beneficial w/o the spacers
  1. Tranny Issue help! 1st shift is slipping/sluggish.2nd and up real quick jerk shift
    By Prixness in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-26-2014, 12:28 PM
  2. Replies: 1
    Last Post: 12-08-2012, 07:39 PM
  3. TB Spacers
    By BillBoost37 in forum General Tech Discussion
    Last Post: 12-22-2010, 06:08 PM
  4. spacers?
    By crywolf in forum Tires & Wheels
    Last Post: 12-29-2008, 12:49 PM
