Thread: Multiple Issues... maybe
Results 1 to 4 of 4
  1. #1 Multiple Issues... maybe
    Aug 2017
    Washougal Washington
    So I have a 2006 Pontiac Grand prix 3.6L V6
    Overall Symptoms: Engine loses power then surges/jerks, Metallic Grinding on front driver side(NOT when braking), gouging in Driver side rotor(Brake pad worn only on driver side), Metallic jangling sound over bumps, Engine Light Always ON and Flashes when driving, RPMs Pulse when Idling or around 2000 RPMs causing a stall(started today), Water sloshing sound when accelerating or turning
    What I have done recently: I changed the upper and lower head gaskets(Not sure if I set the Lash properly on the rockers) and Timing cover gasket(due to Coolant leak), new spark plugs, new wires, new coil, new power module
    Engine Code: Random Misfires
    I work on my own car, but I am just learning how. I need this car to get to School and Work and I don't have alot of money. I am trying to Dial into the root cause without spending a boatload of money on things that don't work.
    Any Help would be greatly appreciated.
  2. #2 Re: Multiple Issues... maybe
    was it running ok before all that work? and why in the world would you pull the heads off? they hardly every blow a gasket.
    theres no rocker lash, you tq em to 25lb's if you used reusable bolts, 11 and like 90 degrees iirc for new stock bolts that are tty.
    flashing light, thats either it needs a tune up really bad, plug wires are on wrong, or, the cat is clogged up. hi miles na engines clog the cat all the time.
    get your codes scanned at a parts store, its free at most places.
  3. #3 Re: Multiple Issues... maybe
    Aug 2017
    I pulled them because a mechanic told me that the gaskets were blown.
    It was surging before all the work, but all the other issues appeared recently.
    And my engine is almost at 200k miles
  4. #4 Re: Multiple Issues... maybe
    ok, lets get it scanned, post your codes, cause the codes always lead to the answer.
    flashing cel tho, could be the cat, they tend to feel weak, lack of power, and sounds like a vacuum with a full bag when you floor it.
    you can take the up stream o2 out run it with the hole open, see if its got more power. this lets the exhaust out pre cat.
    or drive it some what hard at night and look under the car and see if its glowing red.
  1. Multiple issues
    By dpmeeks in forum General Tech Discussion
    Last Post: 08-05-2015, 06:07 AM
  2. Multiple Issues
    By aprose in forum General Tech Discussion
    Last Post: 04-23-2012, 01:04 PM
  3. Multiple car issues.
    By suzie in forum General Tech Discussion
    Last Post: 02-25-2011, 07:00 PM
  4. 97 GTP multiple issues
    By Ainrev in forum General Tech Discussion
    Last Post: 02-04-2011, 04:06 PM
  5. multiple issues, help?
    By Brammer in forum General Tech Discussion
    Last Post: 10-04-2010, 03:37 PM
