Thread: Shifting problem 99 GT
Results 1 to 7 of 7
  1. #1 Shifting problem 99 GT
    Jan 2017
    Boise, Idaho
    So my tranny is shifting weird and has been doing so for about a month or two. It'll go into first gear around 20mph and then won't go into another gear until 45mph which is overdrive. So my question is, is this a transmission issue or something else? After it hits 45mph, if I accelerate to higher speeds I can see/feel it downshift at times. Was wondering if maybe my TPS is bad or needs adjusted? I'm selling my GP tomorrow and wanted to figure out what the issue is so I could tell the person who buys it. My MAF sensor has a low voltage going to it. Threw a p0102 code last time a code reader was plugged in. Never had any transmission codes thrown. I was wondering if maybe changing the transmission fluid and filter would make a difference? I've also read that sometimes a clogged fuel filter can cause shifting issues as well. The car drives fine otherwise and has not given me any other issues as far as drivability goes. Any info would be greatly appreciated!
  2. #2 Re: Shifting problem 99 GT
    May 2008
    Schuyler, NE
    The maf sensor has an effect on the transmission shifting, so that could be your problem.
  3. #3 Re: Shifting problem 99 GT
    Jan 2017
    Boise, Idaho
    Okay that's kinda what I wondered. It shifted perfect before then. I just don't have a torx security bit to take off the MAF sensor and clean or replace it.
  4. #4 Re: Shifting problem 99 GT
    St. Louis
    Got a dremel tool or hacksaw? If so, cut a slot in the screw head and use a regular flathead screwdriver to remove it.
  5. #5 Re: Shifting problem 99 GT
    Jan 2017
    xx
    Every auto parts store I've ever seen carries a small set of security torx bits..
  6. #6 Re: Shifting problem 99 GT
    Jan 2017
    Boise, Idaho
    Well I cleaned the MAF sensor. That's not the issue. Still has problems. I just wanna get rid of the damn car. Having a ***** of a time doing so.
  7. #7 Re: Shifting problem 99 GT
    GTP Level Member
    springfield IL
    Quote Originally Posted by Pontiacidaho View Post
    replace it.. i had same issue years ago!!
  1. 97 gtp shifting problem
    By ScreaminZ in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-10-2014, 04:34 PM
  2. problem shifting
    By tomtom123 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2013, 09:39 PM
  3. shifting problem
    By kenconerly in forum General Grand Prix Discussion
    Last Post: 11-19-2012, 01:06 PM
  4. 95 GP Shifting problem
    By DaveB in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 10-22-2011, 03:53 PM
  5. Shifting problem, pls help
    By mtrmes02 in forum General Tech Discussion
    Last Post: 01-23-2010, 09:07 PM
