Thread: New manifold?
Results 1 to 11 of 11
  1. #1 New manifold?
    Sep 2012
    fort Wayne, in
    So I'm going to be replacing the upper and lower intake gaskets, valve cover gaskets and doing a fluid flush. I'm probably going to go with an hv3 with all this too, would it benefit going with a new upper manifold or no?
  2. #2 Re: New manifold?
    St. Louis
    I would since you're in that far. Then you can replace the EGR stovepipe with the updated version as well. You could also mod the LIM while its off to block the coolant ports to the TB.
  3. #3 Re: New manifold?
    Sep 2012
    fort Wayne, in
    What does that do? Blocking off the coolant ports?
  4. #4 Re: New manifold?
    St. Louis
    Keeps the possibility of the TB gaskets leaking/blowing and causing a coolant leak. There is no real need to heat up the TB with coolant in your climate. If you do this then also hog out the coolant crossover in the LIM under that little cover held on with 2 bolts. There is an "I" shaped divider in there. When blocking the top ports you ream out this area to restore the lost flow and also help cool the 2 middle cylinders better, or so I've read. I did it on my 00 GT just recently and everything works fine. Took longer to find the right NPT plugs and tap than anything. Also gave me a reason to get a new bit for my Dremel, lol..
  5. #5 Re: New manifold?
    Sep 2012
    fort Wayne, in
    And with the new intake does Dorman work well or no? From rockauto.com
  6. #6 Re: New manifold?
    St. Louis
    Should be as long as it's the updated design.
    Here's a few threads that explain the coolant ports and LIM change (courtesy of Scotty):
    do this http://www.grandprixforums.net/threa...w-to-Mod-a-LIM
    and then check for this. http://www.grandprixforums.net/threa...36-UIM-Failure
  7. #7 Re: New manifold?
    Sep 2012
    fort Wayne, in
    The Dorman is plastic material and the a.c. Delco is nylon. Guessing the a.c. Delco is better? Also I noticed the Dorman is 6.5in in height vs A.C Delco is only 5.5? Why the difference?
  8. #8 Re: New manifold?
    St. Louis
    No idea. Never measured the ones I installed. The Delco one could be better, never tried that one. I've only had one failure on the Dorman one, but that was after a lot of miles (like 100K+).
  9. #9 Re: New manifold?
    Sep 2012
    fort Wayne, in
    Awesome! Thanks man I went with the Dorman one just because I've read good things and I'm going with the hv3 insert too so I don't think that one inch will be a huge difference
  10. #10 Re: New manifold?
    St. Louis
    No problem. Just watch when you torque the UIM bolts down. For some reason the drivers side long bolt (near the TB and EGR) wanted to start cracking the replacement UIM when I got it close to factory spec., even after following the correct bolt tightening order. Not sure why it happened but it's sealed up just fine so I left well enough alone. Just a heads up.
  11. #11 Re: New manifold?
    Sep 2012
    fort Wayne, in
    I appreciate it!
  1. Corroded LIM Lower intake manifold Get new manifold or is this one ok
    By jj5428 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-16-2015, 07:04 AM
  2. Has anyone used this manifold?
    By painthorsemoe in forum 5.3L V8 (LS4)
    Last Post: 08-01-2013, 12:09 PM
  3. Manifold
    By GrandPriest24 in forum General Grand Prix Discussion
    Last Post: 02-28-2013, 06:09 PM
  4. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  5. Which intake manifold is better?
    By ya61x in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-12-2010, 11:51 PM
