Thread: Cylinder Head Casting Numbers ?
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #21 Re: Cylinder Head Casting Numbers ?
    i would get new seals, then a spring compressor, and a tube of lapping compound, lap the valves, then install new seals, clean up the mating surfaces and bolt that f er back on.
  2. #22 Re: Cylinder Head Casting Numbers ?
    Oct 2013
    Clovis, California USA
    Scottydoggs - Would you trust a cylinder head off ebay ? The one below seems awfully cheap.
    http://www.ebay.com/itm/95-01-Buick-...lWtPKH&vxp=mtr
  3. #23 Re: Cylinder Head Casting Numbers ?
    Antioch, IL
    your looking at a 125$ head when you can get one for $45 why
    2009 Challenger SRT8
    Expert at being gay.
  4. #24 Re: Cylinder Head Casting Numbers ?
    buy the junk yard head, watch some videos on valve lapping, its easy.
  5. #25 Re: Cylinder Head Casting Numbers ?
    Oct 2013
    Hey guys - if I pull the head from the salvage yard, should I pull the rear head or the front head ? Are they both the same ? I'm thinking it might be chicken chit to pull the front head. I'm already disappointed in myself enough as it is.
  6. #26 Re: Cylinder Head Casting Numbers ?
    oh lord, thats a bad story.
    be best to hit up a junk yard and snag a head off any 3800 thats na. you can grab the front head thats easier to take off, same head.
    you also need new head bolts.
    you need to read your own thread sometimes
  7. #27 Re: Cylinder Head Casting Numbers ?
    Oct 2013
    I'm thinking it might be a good idea to pull the rear head anyway; that way if there's any surprises, it'll be at the salvage yard instead of at home.
  8. #28 Re: Cylinder Head Casting Numbers ?
    if you want to do extra work thats your call. but the heads are the same.
  9. #29 Re: Cylinder Head Casting Numbers ?
    Oct 2013
    I got a head out of the salvage yard. One of the head bolts won't come out because the exhaust manifold stud is blocking its way out. There's two of those studs on the exhaust side of the head that stick up past the surface by 36mm. I don't know what the total length is, but I wish I had the size specs and a GM part number. The stud is going to need to be replaced because the head bolt was rubbing on it during removal. You guys know of a source to get those studs from ?
  10. #30 Re: Cylinder Head Casting Numbers ?
    put a socket on it and take it out, then re use it. 4.5 mm iirc.
  11. #31 Re: Cylinder Head Casting Numbers ?
    Oct 2013
    Scottydoggs - what if I needed to replace it; where do they come from ?
    I don't want aftermarket. I want real GM with the hex on the end.
  12. #32 Re: Cylinder Head Casting Numbers ?
    it should come out. if not take one from your old head.
    napa also sells stud kits. take a bolt in and match it up. studs and nuts work much better really.
  13. #33 Re: Cylinder Head Casting Numbers ?
    GM buys from various suppliers, the same way auto part stores do. It just won't say AC Delco on the bag you buy.
    I always find OEM style bolt/stud kits from Napa, they are perfectly fine.
    I suggest heating those ****ers up before you try to remove them too, makes them come out like butter without a chance of rounding the hex head.
  14. #34 Re: Cylinder Head Casting Numbers ?
    Oct 2013
    http://zzperformance.com/3800/bolts/...old-studs.html
    A friend on another forum sent me that link. I'm good now.
  1. L67 Cylinder Head
    By stonecold0469 in forum Wanted To Buy - Parts
    Last Post: 09-16-2016, 03:27 PM
  2. Best head casting #?
    By apierce1289 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2013, 11:37 AM
  3. Cylinder head problems
    By codytuttle96 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2013, 01:57 PM
  4. I need l32 cylinder head casting numbers if anyone has a valve cover off
    By theonlysi1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2012, 11:37 PM
  5. cylinder head question
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2011, 09:48 PM
