Thread: Power Steering Leak
Results 1 to 2 of 2
  1. #1 Power Steering Leak
    May 2012
    Bloomington, IN
    Looks like I have a PS leak from the plastic reservoir. I assume the PS pump and reservoir are one unit so its a total replacement but wanted to confirm. Let me know, thanks.
  2. #2 Re: Power Steering Leak
    GrandPrix Junkie
    St. Louis
    Yep, just grab yourself a GM pulley removing tool and swap out the pump. Or hit up a Jy and save some money and find one that isn't leaking. When you go to swap it out don't forget that the rear knock sensor wire harness is attached to the pump so be sure to remove it before you remove the PS pump/res. or you'll be having a lot more fun that originally thought.
  1. Power Steering Leak
    By ttobo in forum General Tech Discussion
    Last Post: 09-13-2014, 09:15 PM
  2. Power steering leak
    By napes65 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-01-2011, 11:20 AM
  3. Power steering leak
    By dagger in forum Brakes/Suspension/Chassis
    Last Post: 06-26-2011, 07:13 PM
  4. Power Steering Leak
    By trailshredder in forum General Tech Discussion
    Last Post: 12-23-2010, 11:12 AM
  5. Power Steering leak
    By jokyfo in forum General Tech Discussion
    Last Post: 10-30-2010, 12:37 AM
