Thread: Leaking coolant - head gasket?
Results 1 to 17 of 17
  1. #1 Leaking coolant - head gasket?
    Jan 2017
    Novato
    Hey,
    my Grand Prix 2006 is leaking coolant very fast without any obvious leaking spots. Whole coolant reservoir gets empty in about 30 miles. Some time ago I also noticed the oil consumption is rising up (cca 1 quarter of oil on 1500 miles).
    I am afraid its the head gasket. Does anyone here have experience with the replacement? I wasnt able to find any tutorial video how to do that for this car.
    Thanks for any tips!
  2. #2 Re: Leaking coolant - head gasket?
    GT Level Member WickedGoat's Avatar
    Dec 2014
    Missouri
    Pull the oil dipstick and see if you have evidence of coolant and oil mixing. 2nd thing, look at the lower intake manifold where it meets the front cylinder head and see if you see coolant residue anywhere. You can fill the car up with water and run it. See if there is any bubbling in the overflow bottle. See if there is any white smoke from the exhaust. Those are tell tales of a head gasket problem. You can also get a coolant system pressure tester and test to see if the coolant leak is external. Replacing the head gaskets requires a full top end tear down and sending the heads to a machine shop to be checked milled if necessary... Not a job for an inexperienced person to do.
    2014 Chevy Impala LTZ Limited -- Silver/Black, Grand Prix replacement
    2004 Pontiac GTO -- my garage queen
    2004 GMC Yukon SLT -- wife's daily driver
  3. #3 Re: Leaking coolant - head gasket?
    you see any leaks under the car or wetness around the engine, belt side?
    the oil, you might have a clogged up pcv valve.
  4. #4 Re: Leaking coolant - head gasket?
    Jan 2017
    Novato
    Thanks for reply! I will take a detail look over weekend
  5. #5 Re: Leaking coolant - head gasket?
    Jan 2017
    Novato
    Soo its leaking somewhere in the back part of the engine (cca where the wheels ends), but I wasnt able to find the spot where is it leaking from. When I start the engine on and wait few minutes I can see lots of drops from there. These drops looks quite oily. The oil level is much above high limit as well.
    Its old car with harsh transmission, doesn't worth investing over 1000$ for repair so I am thinking to try my chances and replace the head gasket on my own. Is it doable for amateur? I replaced thermostat, water pump and breaks in the past, but this looks much more challenging :/
  6. #6 Re: Leaking coolant - head gasket?
    oil over filled and looks like milk shake is the upper intake failed on you. heres whats going on http://www.grandprixforums.net/threa...36-UIM-Failure
    heads hardly ever fail, but that upper intake sure does. way less work then head gaskets too.
    id drop the oil see what it looks like. dont drive it or it will die for sure.
    edit, re read 1 st post 06 has th emetal itake and that dont fail to often, but worth looking into, never know. head gaskets are rare still.
    start with a compression test.
  7. #7 Re: Leaking coolant - head gasket?
    Jan 2017
    Novato
    Thanks for helping!
    The oil doesnt look milky at all :/ Not sure about the white smoke (I can smell steam, but some time after starting the engine the white smoke disappeared). Engine temperature is above normal, but still far from red zone.
    I will try to connect diagnostic to see what the computer says.
  8. #8 Re: Leaking coolant - head gasket?
    thats winter, once the exhaust gets heated up it stops seaming off the cold moisture.
  9. #9 Re: Leaking coolant - head gasket?
    Jan 2017
    Novato
    I found stream of water leaking somewhere from top of the engine. It leaks a lot, but I cant get any closer to that spot. Any ideas what could be the leaking spot? The picture is done from front wheel spot next to passenger seat. Btw I checked oil and it smells like gas.
    Leaking coolant - head gasket? Attached Images
  10. #10 Re: Leaking coolant - head gasket?
    that looks like a lower elbow blew out. or worst case a freeze out plug rotted out.
    the bracket the alt is bolted to has the two heater hoses off it, if you look close they are tubes through the bracket, engine off, follow the outer hose tube in to the engine, see if its wet .
    hows the heat? it working?
  11. #11 Re: Leaking coolant - head gasket?
    Jan 2017
    Novato
    I removed alternator and timing belt and checked the elbows, one of them is cracked (the front one) not sure if it explains the leaking spot. I guess it worth trying with new elbows again.
    Btw does the gasket should look like this? It looks like someone was trying to fill some holes around, doesnt it?
  12. #12 Re: Leaking coolant - head gasket?
    you can, just host the photos else where.
    you need to clean the 4 holes good, fine sand paper is ok, lube the o rings with oil, then slide them in.
    they sell metal elbows now. replaces the plastic crap that blows out.
  13. #13 Re: Leaking coolant - head gasket?
    Jan 2017
    Novato
    Oh cool, thanks!
  14. #14 Re: Leaking coolant - head gasket?
    what part we looking at here? the rubber strip under the lim? thats normal.
  15. #15 Re: Leaking coolant - head gasket?
    If that "gasket" picture question is at the corner where the LIM meets the engine block, that is completely normal. Just looks like RTV that must be put there.
  16. #16 Re: Leaking coolant - head gasket?
    Jan 2017
    Novato
    Oh I see, I will try new elbows during the week and see if it solves my leaks.
  17. #17 Re: Leaking coolant - head gasket?
    May 2012
    Bloomington, IN
    Grab the aluminum ones, worth the money.
  1. Head gasket or something else (pushing coolant out)
    By 2004l67 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2015, 03:54 PM
  2. Head gasket and head crack questions.
    By deib in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2012, 03:50 PM
  3. Leaking head gasket?
    By vertebrate in forum General Tech Discussion
    Last Post: 08-28-2012, 12:31 PM
  4. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
