Thread: 99 Pontiac Grand Prix GT Whining Noise When Accelerating
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 64
  1. #1 99 Pontiac Grand Prix GT Whining Noise When Accelerating
    Jan 2017
    Boise, Idaho
    So I recently bought this car thru a private sale. Since the night I bought it, it's been making a weird whining noise when I accelerate. Almost sounds like a high pitched turbo noise but my engine isn't supercharged. Also feels like the car is pulling back when trying to accelerate almost like it's having a hard time accelerating. The RPM's seem to have something to do with it. Any ideas on what it could be?
  2. #2 Re: 99 Pontiac Grand Prix GT Whining Noise When Accelerating
    Have you checked the transmission fluid level?
  3. #3 Re: 99 Pontiac Grand Prix GT Whining Noise When Accelerating
    Jan 2017
    Boise, Idaho
    Yeah I filled it the day after I bought the car because I noticed the noise and wondered if that's what it was. Still makes the noise.
  4. #4 Re: 99 Pontiac Grand Prix GT Whining Noise When Accelerating
    take the belts off fire it up see if the sound is gone. if it is gone, spin all your pulleys till you find one thats not smooth spinning.
    if you think your feeling real drag on the engine the ac compressor might be locking up, we've seen them stop a engine 100% from turning. water pumps too.
  5. #5 Re: 99 Pontiac Grand Prix GT Whining Noise When Accelerating
    Jan 2017
    Boise, Idaho
    Okay. It slightly makes the noise when the car is in park and you rev the engine. But it's mostly when your driving and accelerate. It's almost like a winding noise. Like it when's down when you let off the gas.
  6. #6 Re: 99 Pontiac Grand Prix GT Whining Noise When Accelerating
    GTP Level Member
    Aug 2012
    st louis park, MN
    Power steering is a common whine on these cars. Even with proper function and fluid level they can still make a mild whining noise that sound like a supercharger.
    I'd second scotty's suggestion on taking off the belt and spinning/wiggling the pulleys by hand to see if one is noise, worn or has play.
    I think most people will ask for more details about the resistance you are feeling before they can help more. I'd start with some really basic things though: make sure the e-brake isn't sticking and all the wheels spin freely when they are up off the ground, tire inflation seems obvious but you can feel that if they are low enough.
    More details and we can try to help!
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  7. #7 Re: 99 Pontiac Grand Prix GT Whining Noise When Accelerating
    Jan 2017
    Boise, Idaho
    Okay. Theres a light on that says Trac off. I push the Trac button and the light stays on. It's been on since I bought the car. Wondering if that has something to do with it?
  8. #8 Re: 99 Pontiac Grand Prix GT Whining Noise When Accelerating
    Jan 2017
    Boise, Idaho
    Also somewhat of a slight burning smell near the grille when I shut the car off. Can't tell what the smell is. Whether it's coolant or oil.
  9. #9 Re: 99 Pontiac Grand Prix GT Whining Noise When Accelerating
    abs light on too? either way its abs related, only way to really figure out just the tc button is to scan it with a abs scanner.
    and no, its not gonna whine, you just have no traction control. like the wheels will spin freely in the snow or wet roads.
  10. #10 Re: 99 Pontiac Grand Prix GT Whining Noise When Accelerating
    Jan 2017
    Boise, Idaho
    It almost sounds like it could be a power steering pump but it steers fine.
  11. #11 Re: 99 Pontiac Grand Prix GT Whining Noise When Accelerating
    Remove the belt and take it up the street and back.
    You can run it for several minutes without the belt just to check stuff.
  12. #12 Re: 99 Pontiac Grand Prix GT Whining Noise When Accelerating
    Jan 2017
    Boise, Idaho
    okay if i remove the belt and do that, what do i need to check? what do i need to listen for?
  13. #13 Re: 99 Pontiac Grand Prix GT Whining Noise When Accelerating
    If the sound goes away, then you know where to look. Be it the power steering or a loud pulley.
    If the noise is still there, then it's nothing driven off the engine belt and likely a transmission noise.
  14. #14 Re: 99 Pontiac Grand Prix GT Whining Noise When Accelerating
    Jan 2017
    Boise, Idaho
    oh ok
  15. #15 Re: 99 Pontiac Grand Prix GT Whining Noise When Accelerating
    Jan 2017
    Boise, Idaho
    My cousin who is a mechanic looked at it and said it sounds like the power steering pump. But it still steers fine. I'm wondering if it's maybe the pulley on the pump as well? Could I run the car without the ps pump for a short period of time to see if it makes the noise?
  16. #16 Re: 99 Pontiac Grand Prix GT Whining Noise When Accelerating
    damn it listen and do what we told ya. or dont.
    and no you cant drive a day with no power steering pump. unless you want to change the rack too. 2 minutes is fine tho for the test we told ya to do days ago.
    and stop having people who just "look" at it and shut the hood, they are no help are they? pop the hood and put some time in. what you gonna do when you find the bad part? wait for it to be repaired via magic like now?
  17. #17 Re: 99 Pontiac Grand Prix GT Whining Noise When Accelerating
    May 2016
    Lincoln, Nebr
    lmao Scotty, that brightened up my morning. Pontiacidaho, seriously though - do what they said. Maybe check your PS fluid level too, I didn't see where you mentioned that you've checked this. They do whine quite a bit, proper fluid level can help, but PS inherently has a mild whine when parking and tight turns and stuff.
  18. #18 Re: 99 Pontiac Grand Prix GT Whining Noise When Accelerating
    Why haven't you tried removing the belt yet?
    Should we type this 20 more times?
  19. #19 Re: 99 Pontiac Grand Prix GT Whining Noise When Accelerating
  20. #20 Re: 99 Pontiac Grand Prix GT Whining Noise When Accelerating
    21 times for effort.
  1. rattling noise 2004 pontiac grand prix
    By gordzilla33 in forum General Tech Discussion
    Last Post: 11-21-2021, 08:59 PM
  2. 08 pontiac grand prix, clicking when accelerating. Smoke comes out exhaust when hitt
    By slipknothollywood in forum General Grand Prix Discussion
    Last Post: 06-10-2016, 09:53 AM
  3. Loud engine noise when accelerating (sometimes) 2001 pontiac grand prix gtp
    By Poems in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-20-2012, 01:31 PM
  4. Hissing Noise On A 1999 Pontiac Grand Prix
    By GrandPrixChic in forum General Tech Discussion
    Last Post: 12-24-2010, 02:00 AM
  5. 1996 Pontiac Grand Prix SE noise
    By moospis in forum General Tech Discussion
    Last Post: 08-20-2010, 04:51 AM
